July 5, 201313 yr I have the following MB/CPU: Supermicro - X9SCL/X9SCM Intel® Xeon® CPU E31230 @ 3.20GHz - 3.2 GHz (Retail - CPU/FAN) and the CPU Fan is only running at 2000 RPM and the MB still warns me of CPU temp overheat - right now its at 36C should this CPU fan run faster than 2k or do I have a fan failing? Opinions please... Thanks Myk
July 5, 201313 yr 2000rpm is the base fan speed for a stock Intel heatsink. 36 degrees with a Sandy Bridge E3 with a stock Intel heatsink with the fan running at 2000rpm in the summer time is perfectly reasonable. Not sure why you're getting overheat alarms. Where exactly are you getting these alarms?
July 5, 201313 yr As mrow noted, 36 is a VERY reasonable temp for your CPU, so you should NOT be getting warnings. Check the BIOS thermal control settings ... fan control, temperature alarms, etc. You may have somehow set the alarm threshold far too low.
July 5, 201313 yr Author I get the 2 tone siren sound from the MB cpu speaker and the following shows up in syslog Jul 4 19:39:46 Tower kernel: CPU2: Core temperature above threshold, cpu clock throttled (total events = 1) Jul 4 19:39:46 Tower kernel: CPU5: Core temperature above threshold, cpu clock throttled (total events = 1) Jul 4 19:39:46 Tower kernel: CPU1: Package temperature above threshold, cpu clock throttled (total events = 1) Jul 4 19:39:46 Tower kernel: CPU4: Package temperature above threshold, cpu clock throttled (total events = 1) Jul 4 19:39:46 Tower kernel: CPU3: Package temperature above threshold, cpu clock throttled (total events = 1) Jul 4 19:39:46 Tower kernel: CPU0: Package temperature above threshold, cpu clock throttled (total events = 1) Jul 4 19:39:46 Tower kernel: CPU5: Package temperature above threshold, cpu clock throttled (total events = 1) Jul 4 19:39:46 Tower kernel: CPU5: Core temperature/speed normal Jul 4 19:39:46 Tower kernel: CPU0: Package temperature/speed normal Jul 4 19:39:46 Tower kernel: CPU1: Package temperature/speed normal Jul 4 19:39:46 Tower kernel: CPU3: Package temperature/speed normal Jul 4 19:39:46 Tower kernel: CPU4: Package temperature/speed normal Jul 4 19:39:46 Tower kernel: CPU5: Package temperature/speed normal Jul 4 19:39:46 Tower kernel: CPU2: Core temperature/speed normal That one only lasted for a second, but sometimes in will go until I force the unit cooler with a external box fan. Jul 5 00:20:58 Tower kernel: CPU5: Core temperature above threshold, cpu clock throttled (total events = 96) Jul 5 00:20:58 Tower kernel: CPU2: Core temperature above threshold, cpu clock throttled (total events = 96) Jul 5 00:20:58 Tower kernel: CPU3: Package temperature above threshold, cpu clock throttled (total events = 96) Jul 5 00:20:58 Tower kernel: CPU1: Package temperature above threshold, cpu clock throttled (total events = 96) Jul 5 00:20:58 Tower kernel: CPU4: Package temperature above threshold, cpu clock throttled (total events = 96) Jul 5 00:20:58 Tower kernel: CPU0: Package temperature above threshold, cpu clock throttled (total events = 96) Jul 5 00:20:58 Tower kernel: CPU2: Package temperature above threshold, cpu clock throttled (total events = 95) Jul 5 00:20:58 Tower kernel: CPU0: Package temperature/speed normal Jul 5 00:20:58 Tower kernel: CPU3: Package temperature/speed normal Jul 5 00:20:58 Tower kernel: CPU1: Package temperature/speed normal Jul 5 00:20:58 Tower kernel: CPU4: Package temperature/speed normal Jul 5 00:20:58 Tower kernel: CPU2: Core temperature/speed normal Jul 5 00:20:58 Tower kernel: CPU2: Package temperature/speed normal Jul 5 00:20:58 Tower kernel: CPU5: Core temperature/speed normal And it will do this sometimes just sitting idle with all drives spun down, last night 1 drive and the cache drive was spun up as I was watch a movie... here is a sensors of the machine right now root@Tower:/var/log# sensors coretemp-isa-0000 Adapter: ISA adapter Physical id 0: +44.0 C (high = +74.0 C, crit = +94.0 C) Core 0: +41.0 C (high = +74.0 C, crit = +94.0 C) Core 1: +44.0 C (high = +74.0 C, crit = +94.0 C) Core 2: +43.0 C (high = +74.0 C, crit = +94.0 C) nct6776-isa-0a30 Adapter: ISA adapter Vcore: +0.98 V (min = +0.60 V, max = +1.49 V) in1: +1.87 V (min = +1.62 V, max = +1.99 V) AVCC: +3.30 V (min = +2.96 V, max = +3.63 V) +3.3V: +3.30 V (min = +2.96 V, max = +3.63 V) in4: +1.53 V (min = +1.35 V, max = +1.65 V) in5: +1.27 V (min = +1.13 V, max = +1.38 V) 3VSB: +3.36 V (min = +2.96 V, max = +3.63 V) Vbat: +3.14 V (min = +2.96 V, max = +3.63 V) BackPlane: 0 RPM (min = 300 RPM) ALARM MidPlaneLeft: 0 RPM (min = 300 RPM) ALARM MidPlaneMiddle: 0 RPM (min = 300 RPM) ALARM MidPlaneRight: 0 RPM (min = 300 RPM) ALARM CPU Fan: 1017 RPM (min = 300 RPM) MB Temp: +28.0 C (high = +75.0 C, hyst = +70.0 C) sensor = thermistor CPU Temp: +28.0 C (high = +80.0 C, hyst = +75.0 C) sensor = thermistor AUXTIN: +1.5 C sensor = thermistor PECI Agent 0: +49.5 C (high = +95.0 C, hyst = +92.0 C) cpu0_vid: +0.000 V intrusion0: OK intrusion1: ALARM as it says high temp would be +75, its has never gotten above 38C, btw I have gotten the replacement mid fan plate, just not the PWM fans yet, hence some of the plane readings above This is weird and I dont know what to try to do. Thanks for looking Myk
July 5, 201313 yr Author I looked for alarm threshold the other day and didn't find anything, granted i didn't have much time and looked very quick. I will look again tonight when I get home from work. Thanks Myk
July 5, 201313 yr Hopefully this will prove to be a simple case of a miss-set alarm threshold. Definitely strange !!
July 8, 201313 yr Author Ok, spent hours last night to no end - there is no alarm threshold settings in my bios, current version is at 2.09 I got the lastest bios (2.17 i think) and made a bootable flash drive, books just fine on my windows machine, but for the life of me I can not get it to book on the unraid box. So I have to figure out another way to get something booted. My windows machne can falsh from a non bootable flash drive using its F key during boot. Why does supermicro no do the same. They make it so hard to update ANYTHING.... Suggestions? Myk
