sisren Posted October 7, 2013 Share Posted October 7, 2013 I'm somewhat of a newbie, so please bare with me... I installed a number of new packages (power down, ups) and shutdown my unraid server (everything was working perfectly). I then moved my computer and now it won't boot from the USB key! It recognizes it in BIOS and I have verified that the key does work within windows. Can I just backup the usb key, reformat it, and copy the files back? Or are there other options I can try to recover? Please advise. thanks! Sisren Link to comment
dgaschk Posted October 8, 2013 Share Posted October 8, 2013 Yes, you can do a clean install include formatting. Save the old config folder. After it boots with a clean install, you can restore the config folder and try to boot. Link to comment
sisren Posted October 8, 2013 Author Share Posted October 8, 2013 Thank you. That worked. Link to comment
