CaptainSpalding Posted March 2, 2014 Author Share Posted March 2, 2014 I have now copied 4TB from the old server and I still am going to copy another 4TB before I build parity to the new array. I also want to get those four empty 2TB drives off from my old array. It would be best to remove them at same time? And then create a new config? The chances of losing an extra disk in the process is the same, but I could then I could get more disks out. When a new config is started the parity of old array is lost anyway isn't it? Link to comment
garycase Posted March 2, 2014 Share Posted March 2, 2014 When a new config is started the parity of old array is lost anyway isn't it? Yes, when you do a new config, you then have to do an initial parity sync. The array has no fault-tolerance until that is done. Link to comment
