[SOLVED] Cabling problem... Mini-SAS SFF-8087 cable fixed to to case!
Ok.. this may be a strange one.  I purchased a used Super Micro 933.  It appears the diskcontroller it came with does not support JBOD mode so UNRAID won't work.  So I need a new controller.  No problem.  The problem is there is a pair of Mini-SAS SFF-8087 forward breakout cables fixed to the disk drive end of the case.  The replacement card I want (the only PCI-X cards I can find) require straight SATA connections.  The question is, can I make the new card work without trying to remove the  Mini-SAS SFF-8087 cable?  Can I connect another cable to the  Mini-SAS SFF-8087 which will allow me to connect it to the new controller card?
Thanks in advance.
I wonder if theres a mini-8087 to mini-8087 joiner (female - female), that you could plug the sata ports into via a reverse breakout cable, and then to your fixed mini8087 backplane connection
be a bit of a cabling mess, even if such a thing exists (quick google didnt turn up anything)
shame you cant find a pcix card with 8087 ports - Ive no experience with them though
Thats the first thing I looked for.  The best I found were forward and reverse cables, which I do not believe will do the job.
If the card you are wanting to come from is the AOC-SAT2-MV8 and it goes to a back plane in your case that has a SFF-8087 socket on it?  Then you will be wanting reverse break out cables to go from the AOC-SAT2-MV8 to the SFF-8087 socket on the back plane.  So something like this I think http://www.newegg.com/Product/Product.aspx?Item=N82E16812400143&cm_re=SATA_to_SFF-8087-_-12-400-143-_-Product
Assuming my piecing together of two posts and assumption that your case had a back plane with a SFF-8087 socket.
OK.  Nevermind.  Problem solved. The current cables were "attached" with some kind of rubber that was easy to remove.  I can now use the cards I want with the cables I already have available.  Thanks!
ah happy days
