October 26, 201412 yr Hi. Long time user of unRaid, I want to build an unRaid server that will be able to run a VM to replace my current desktop (i7-920, 24GB ram, R9 290x, Gigabyte GA-EX58-UD5). The server will also run Plex (with transcoding) and CrashPlan, probably directly and not VMed/Dockerized (still open for suggestions). I'm considering using an AMD FX-8350/FX-9370 on a Gigabyte GA-990FXA-UD3 with 32GB... I'll be happy for any advice about the processors and the motherboard, as I've been a long time Intel user, but don't think Intel can compete in the performance/price ratio... ps - AFAIK, unRaid is going to the KVM solution. Is there a reason to go with XEN instead? thanks in advance
October 26, 201412 yr Hi. Long time user of unRaid, I want to build an unRaid server that will be able to run a VM to replace my current desktop (i7-920, 24GB ram, R9 290x, Gigabyte GA-EX58-UD5). The server will also run Plex (with transcoding) and CrashPlan, probably directly and not VMed/Dockerized (still open for suggestions). I'm considering using an AMD FX-8350/FX-9370 on a Gigabyte GA-990FXA-UD3 with 32GB... I'll be happy for any advice about the processors and the motherboard, as I've been a long time Intel user, but don't think Intel can compete in the performance/price ratio... ps - AFAIK, unRaid is going to the KVM solution. Is there a reason to go with XEN instead? thanks in advance We've had some challenges with amd cards on KVM, but we are still looking at it. The issues may be solvable.
October 27, 201412 yr Author So I should look into XEN? I thought I saw somewhere in the forums you guys have chosen to focus on KVM, not XEN, but I might be mistaken.
October 27, 201412 yr Author As for the hardware aspect - opened a new thread over the Hardware section http://lime-technology.com/forum/index.php?topic=35972.0 Just need information about the virtualization support planned for unRaid and will this hardware combination will be fit.
