Advice on low power setup
As part of getting ready to move onto unRAID 6, I  am contemplating retiring my current setup (L3426, X8SIL-F) in favour of something with better power consumption (I run my server 24/7 so consumption matters)
I am fairly brand agnostic when it comes to motherboards, but have been running Supermicro boards for some time because of the feature set. I have not kept abreast of where the market has been going, so I am hoping that someone with requirements similar to mine could drop some recommendations based on what they did.
My requirements for the setup are:
  • Must work with my existing 2x 4GB DDR3 unregistered ECC RAM (Kingston)
  • Low overall power consumption in idle - where it spends most of it's time
  • Must support one, preferably two M1015
  • Must have 4-6 onboard SATA ports - no Marvell controller
  • Must have Intel brand NIC(s) - no RealTek controller
  • Must be able to support transcoding of 2-3 streams (will be running the Plex docker)
  • Must be either Mini-ITX or Micro ATX
  • Could have IPMI (although I find that I use this less as support is only on Windows, an even so seems to be waning - there's always some issue with Java or other)
  • Could have dual NIC
My initial thoughts are that it would be something build around a Haswell generation i3, but I am open to suggestions.
Thanks in advance to suggestions, links to other build threads etc :-)
Regards,
Thomas
...registered ECC calls for older socket 1156 (which you already have) or newer socket 2011.
Hmmm.. Didn't see that coming :-( Maybe I should stick with my unregistered 2x 4GB ECC then. Seems like hanging on to the other modules will increase overall price disproportionately.
Thanks!
..yup, having an X8SIL-F with 32GB RegECC myself, I know how that feels.;-)
I converted it to a nice workstation though...added a x1PCIe GPU card.
With your existing UDIMMs, I recommend the X10SL7-F...14 ports right away...works like a charm.
