matthope Posted May 24, 2016 Share Posted May 24, 2016 Is there any ways to enable my onboard audio because I have an old audio amplifier and i need a line out. If not I will purchase a usb audio card. There is the xml of my VM : <domain type='kvm' xmlns:qemu='http://libvirt.org/schemas/domain/qemu/1.0'> <name>LinuxMint</name> <uuid>e1cfce03-fcf3-f299-e060-4e1465fba847</uuid> <description>HTPC</description> <metadata> <vmtemplate name="Custom" icon="linux.png" os="linux"/> </metadata> <memory unit='KiB'>3145728</memory> <currentMemory unit='KiB'>3145728</currentMemory> <memoryBacking> <nosharepages/> <locked/> </memoryBacking> <vcpu placement='static'>1</vcpu> <cputune> <vcpupin vcpu='0' cpuset='0'/> </cputune> <os> <type arch='x86_64' machine='pc-i440fx-2.3'>hvm</type> </os> <features> <acpi/> <apic/> </features> <cpu mode='host-passthrough'> <topology sockets='1' cores='1' threads='1'/> </cpu> <clock offset='utc'> <timer name='rtc' tickpolicy='catchup'/> <timer name='pit' tickpolicy='delay'/> <timer name='hpet' present='no'/> </clock> <on_poweroff>destroy</on_poweroff> <on_reboot>restart</on_reboot> <on_crash>restart</on_crash> <devices> <emulator>/usr/bin/qemu-system-x86_64</emulator> <disk type='file' device='disk'> <driver name='qemu' type='raw' cache='writeback'/> <source file='/mnt/cache/vdisks/LinuxMint/vdisk1.img'/> <target dev='hdb' bus='virtio'/> <boot order='1'/> <address type='pci' domain='0x0000' bus='0x00' slot='0x04' function='0x0'/> </disk> <controller type='usb' index='0'> <address type='pci' domain='0x0000' bus='0x00' slot='0x01' function='0x2'/> </controller> <controller type='pci' index='0' model='pci-root'/> <controller type='ide' index='0'> <address type='pci' domain='0x0000' bus='0x00' slot='0x01' function='0x1'/> </controller> <controller type='virtio-serial' index='0'> <address type='pci' domain='0x0000' bus='0x00' slot='0x03' function='0x0'/> </controller> <interface type='bridge'> <mac address='52:54:00:06:fa:57'/> <source bridge='br0'/> <model type='virtio'/> <address type='pci' domain='0x0000' bus='0x00' slot='0x02' function='0x0'/> </interface> <serial type='pty'> <target port='0'/> </serial> <console type='pty'> <target type='serial' port='0'/> </console> <channel type='unix'> <source mode='bind' path='/var/lib/libvirt/qemu/channel/target/LinuxMint.org.qemu.guest_agent.0'/> <target type='virtio' name='org.qemu.guest_agent.0'/> <address type='virtio-serial' controller='0' bus='0' port='1'/> </channel> <hostdev mode='subsystem' type='usb' managed='yes'> <source> <vendor id='0x045e'/> <product id='0x00f9'/> </source> </hostdev> <memballoon model='virtio'> <address type='pci' domain='0x0000' bus='0x00' slot='0x05' function='0x0'/> </memballoon> </devices> <qemu:commandline> <qemu:arg value='-device'/> <qemu:arg value='ioh3420,bus=pci.0,addr=1c.0,multifunction=on,port=2,chassis=1,id=root.1'/> <qemu:arg value='-device'/> <qemu:arg value='vfio-pci,host=01:00.0,bus=root.1,addr=00.0,multifunction=on,x-vga=on'/> <qemu:arg value='-device'/> <qemu:arg value='vfio-pci,host=01:00.1,bus=root.1,addr=00.1'/> </qemu:commandline> </domain> My pci device: 00:00.0 Host bridge: Intel Corporation Sky Lake Host Bridge/DRAM Registers (rev 07) 00:01.0 PCI bridge: Intel Corporation Sky Lake PCIe Controller (x16) (rev 07) 00:02.0 VGA compatible controller: Intel Corporation Device 1902 (rev 06) 00:14.0 USB controller: Intel Corporation Sunrise Point-H USB 3.0 xHCI Controller (rev 31) 00:14.2 Signal processing controller: Intel Corporation Sunrise Point-H Thermal subsystem (rev 31) 00:16.0 Communication controller: Intel Corporation Sunrise Point-H CSME HECI #1 (rev 31) 00:17.0 SATA controller: Intel Corporation Device a102 (rev 31) 00:1c.0 PCI bridge: Intel Corporation Sunrise Point-H PCI Express Root Port #5 (rev f1) 00:1d.0 PCI bridge: Intel Corporation Sunrise Point-H PCI Express Root Port #9 (rev f1) 00:1f.0 ISA bridge: Intel Corporation Sunrise Point-H LPC Controller (rev 31) 00:1f.2 Memory controller: Intel Corporation Sunrise Point-H PMC (rev 31) 00:1f.3 Multimedia audio controller: Intel Corporation Sunrise Point-H HD Audio (rev 31) 00:1f.4 SMBus: Intel Corporation Sunrise Point-H SMBus (rev 31) 00:1f.6 Ethernet controller: Intel Corporation Ethernet Connection (2) I219-V (rev 31) 01:00.0 VGA compatible controller: NVIDIA Corporation Device 128b (rev a1) 01:00.1 Audio device: NVIDIA Corporation GK208 HDMI/DP Audio Controller (rev a1) 02:00.0 Ethernet controller: Intel Corporation I211 Gigabit Network Connection (rev 03) My Iommu groups: /sys/kernel/iommu_groups/0/devices/0000:00:00.0 /sys/kernel/iommu_groups/1/devices/0000:00:01.0 /sys/kernel/iommu_groups/1/devices/0000:01:00.0 /sys/kernel/iommu_groups/1/devices/0000:01:00.1 /sys/kernel/iommu_groups/2/devices/0000:00:02.0 /sys/kernel/iommu_groups/3/devices/0000:00:14.0 /sys/kernel/iommu_groups/3/devices/0000:00:14.2 /sys/kernel/iommu_groups/4/devices/0000:00:16.0 /sys/kernel/iommu_groups/5/devices/0000:00:17.0 /sys/kernel/iommu_groups/6/devices/0000:00:1c.0 /sys/kernel/iommu_groups/6/devices/0000:02:00.0 /sys/kernel/iommu_groups/7/devices/0000:00:1d.0 /sys/kernel/iommu_groups/8/devices/0000:00:1f.0 /sys/kernel/iommu_groups/8/devices/0000:00:1f.2 /sys/kernel/iommu_groups/8/devices/0000:00:1f.3 /sys/kernel/iommu_groups/8/devices/0000:00:1f.4 /sys/kernel/iommu_groups/8/devices/0000:00:1f.6 Thanks for your help Link to comment
