S2600CP Motherboard - CPU Temps & Fan Control
As I know I have seen a few S2600CP builds in this forum I was wondering if anybody has gotten cpu fan speed throttling working?
My cpu fan seems to always run at 100% which is quite noisy on my Cooler Master 212 Evo and it's driving me nuts. Can anybody point me in the direction of how I can get the temperature based variable fan speed working?
root@Tower:~# sensors
coretemp-isa-0000
Adapter: ISA adapter
Physical id 0:  +34.0°C  (high = +90.0°C, crit = +100.0°C)
Core 0:         +33.0°C  (high = +90.0°C, crit = +100.0°C)
Core 1:         +33.0°C  (high = +90.0°C, crit = +100.0°C)
Core 2:         +31.0°C  (high = +90.0°C, crit = +100.0°C)
Core 3:         +29.0°C  (high = +90.0°C, crit = +100.0°C)
Core 4:         +34.0°C  (high = +90.0°C, crit = +100.0°C)
Core 5:         +33.0°C  (high = +90.0°C, crit = +100.0°C)
Core 6:         +33.0°C  (high = +90.0°C, crit = +100.0°C)
Core 7:         +31.0°C  (high = +90.0°C, crit = +100.0°C)
i350bb-pci-0700
Adapter: PCI adapter
loc1:         +52.0°C  (high = +120.0°C, crit = +110.0°C)
Additionally, pwmconfig doesn't detect / show anything.
root@Tower:~# pwmconfig
# pwmconfig revision 6243 (2014-03-20)
This program will search your sensors for pulse width modulation (pwm)
controls, and test each one to see if it controls a fan on
your motherboard. Note that many motherboards do not have pwm
circuitry installed, even if your sensor chip supports pwm.
We will attempt to briefly stop each fan using the pwm controls.
The program will attempt to restore each fan to full speed
after testing. However, it is ** very important ** that you
physically verify that the fans have been to full speed
after the program has completed.
/usr/sbin/pwmconfig: There are no pwm-capable sensor modules installed
Hey mate,
Did you end up figuring something out for this?
Ted.
  • 3 months later...
Has anyone been able to get the fan control working? If yes, what did you use/do? Currently I am able to monitor cpu/mobo temp with dynamix System temp plugin but fan is not being read even though I have 2 pwm fans plugged in.
Haven't made any progress on the pwm front. I installed the dynamix core temp plugin along with perl and re-ran sensors-detect but am stuck in regards to loading the required module / driver for pwm.
Any other s2600cp motherboard users out there?
Hi
Have you heard about SDR BIOS file ??  "Intel 2600CP SDR File Hacking"
It seems fan control speed is done at bios level , and fans need to be 4 pin cause 3 pins fan will always run 100%
I am sorting this info out also for myself
Bye
  • 2 years later...
anyone find a solution to this problem?
Someone on this forum must have found a solution?
  • 2 years later...
I know this is old, but did/has anyone got this working???
