Need guide to install os in unraid and help to run unraid faster
HI,
I tried to install some os in vm
but it can't work
I install unbuntu,steam os,deibian
Not one of them work
Is there guide on who to install os ?
And i have Win 10 install and it works
And i notice that when i power the pc it take to long to run unraid Like 10 Min+
And when i pass openelec to gpu sometime it not working
I hope you guys help me to install the os and to run the unraid a lot faster
tower-diagnostics-20160624-1006.zip
With the lack of detail in your post, I wouldn't expect much help as nobody really will know where to start.  Post XMLs, hardware specs and diagnostics.  If Unraid is taking ten minutes to start something is very wrong...
Sorry CHBMB
here are the hardware specs
M/B: ASRock - X79 Extreme11
CPU: Intel® Core™ i7-3970X CPU @ 3.50GHz
64GB Ram
Storage 46TB
Unraid 6.1.9
XML for debian
<domain type='kvm'>
  <name>Debian</name>
  <uuid>8b32d930-8503-d401-b73f-bf2b04f18fbd</uuid>
  <metadata>
    <vmtemplate name="Custom" icon="debian.png" os="debian"/>
  </metadata>
  <memory unit='KiB'>2097152</memory>
  <currentMemory unit='KiB'>2097152</currentMemory>
  <memoryBacking>
    <nosharepages/>
    <locked/>
  </memoryBacking>
  <vcpu placement='static'>4</vcpu>
  <cputune>
    <vcpupin vcpu='0' cpuset='0'/>
    <vcpupin vcpu='1' cpuset='1'/>
    <vcpupin vcpu='2' cpuset='2'/>
    <vcpupin vcpu='3' cpuset='3'/>
  </cputune>
  <os>
    <type arch='x86_64' machine='pc-q35-2.3'>hvm</type>
  </os>
  <features>
    <acpi/>
    <apic/>
  </features>
  <cpu mode='host-passthrough'>
    <topology sockets='1' cores='4' threads='1'/>
  </cpu>
  <clock offset='utc'>
    <timer name='rtc' tickpolicy='catchup'/>
    <timer name='pit' tickpolicy='delay'/>
  </clock>
  <on_crash>restart</on_crash>
  <devices>
    <emulator>/usr/bin/qemu-system-x86_64</emulator>
      <source file='/mnt/user/vdisks/Debian/vdisk1.img'/>
      <target dev='hdb' bus='virtio'/>
      <boot order='1'/>
      <address type='pci' domain='0x0000' bus='0x02' slot='0x04' function='0x0'/>
    </disk>
      <source file='/mnt/user/ISOs/debian-8.5.0-amd64-CD-1.iso'/>
      <target dev='hda' bus='sata'/>
      <readonly/>
      <boot order='2'/>
    </disk>
      <address type='pci' domain='0x0000' bus='0x02' slot='0x02' function='0x7'/>
    </controller>
      <master startport='0'/>
      <address type='pci' domain='0x0000' bus='0x02' slot='0x02' function='0x0' multifunction='on'/>
    </controller>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x1f' function='0x2'/>
    </controller>
    <controller type='pci' index='0' model='pcie-root'/>
    <controller type='pci' index='1' model='dmi-to-pci-bridge'>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x1e' function='0x0'/>
    </controller>
    <controller type='pci' index='2' model='pci-bridge'>
      <address type='pci' domain='0x0000' bus='0x01' slot='0x01' function='0x0'/>
    </controller>
      <address type='pci' domain='0x0000' bus='0x02' slot='0x03' function='0x0'/>
    </controller>
    <interface type='bridge'>
      <mac address='52:54:00:1f:95:12'/>
      <source bridge='br0'/>
      <model type='virtio'/>
      <address type='pci' domain='0x0000' bus='0x02' slot='0x01' function='0x0'/>
    </interface>
    <serial type='pty'>
      <target port='0'/>
    </serial>
    <console type='pty'>
    </console>
    <channel type='unix'>
      <source mode='bind' path='/var/lib/libvirt/qemu/channel/target/Debian.org.qemu.guest_agent.0'/>
    </channel>
    <input type='tablet' bus='usb'/>
    <graphics type='vnc' port='-1' autoport='yes' websocket='-1' listen='0.0.0.0' keymap='en-us'>
    </graphics>
    <video>
      <model type='vmvga' vram='16384' heads='1'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x01' function='0x0'/>
    </video>
    <memballoon model='virtio'>
      <address type='pci' domain='0x0000' bus='0x02' slot='0x05' function='0x0'/>
    </memballoon>
  </devices>
</domain>
xml for Steam OS
<domain type='kvm'>
  <name>Steam OS</name>
  <uuid>97fb0bb9-6c19-1905-67d0-b316950ade36</uuid>
  <metadata>
    <vmtemplate name="Custom" icon="steamos.png" os="steamos"/>
  </metadata>
  <memory unit='KiB'>8388608</memory>
  <currentMemory unit='KiB'>8388608</currentMemory>
  <memoryBacking>
    <nosharepages/>
    <locked/>
  </memoryBacking>
  <cputune>
    <vcpupin vcpu='0' cpuset='4'/>
    <vcpupin vcpu='1' cpuset='5'/>
    <vcpupin vcpu='2' cpuset='6'/>
    <vcpupin vcpu='3' cpuset='7'/>
  </cputune>
  <os>
    <type arch='x86_64' machine='pc-q35-2.2'>hvm</type>
  </os>
  <features>
    <acpi/>
    <apic/>
  </features>
  </cpu>
  </clock>
  <devices>
      <source file='/mnt/user/vdisks/Steam OS/vdisk1.img'/>
      <boot order='1'/>
    </disk>
      <source file='/mnt/user/ISOs/SteamOSDVD.iso'/>
      <readonly/>
      <boot order='2'/>
    </disk>
    </controller>
    </controller>
    </controller>
    </controller>
    </controller>
    </controller>
      <mac address='52:54:00:e2:a1:b2'/>
    </interface>
    <serial type='pty'>
      <target port='0'/>
    </serial>
    </console>
      <source mode='bind' path='/var/lib/libvirt/qemu/channel/target/Steam OS.org.qemu.guest_agent.0'/>
    </channel>
    </graphics>
    <video>
    </video>
    </memballoon>
  </devices>
</domain>
XML for unbuntu
<domain type='kvm' id='17'>
  <name>kubutute</name>
  <uuid>0aa708de-9488-9853-22c8-b71a84ad9483</uuid>
  <metadata>
    <vmtemplate name="Custom" icon="ubuntu.png" os="ubuntu"/>
  </metadata>
  <memoryBacking>
    <nosharepages/>
    <locked/>
  </memoryBacking>
  <cputune>
  </cputune>
  <resource>
  </resource>
  <os>
    <type arch='x86_64' machine='pc-i440fx-2.3'>hvm</type>
  </os>
  <features>
    <acpi/>
    <apic/>
  </features>
  </cpu>
  </clock>
  <devices>
      <source file='/mnt/user/vdisks/kubutute/vdisk1.img'/>
      <backingStore/>
      <boot order='1'/>
      <alias name='virtio-disk1'/>
    </disk>
      <source file='/mnt/user/ISOs/kubuntu-16.04-desktop-amd64.iso'/>
      <backingStore/>
      <target dev='hda' bus='ide'/>
      <readonly/>
      <boot order='2'/>
      <alias name='ide0-0-0'/>
    </disk>
    <controller type='usb' index='0'>
      <alias name='usb'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x01' function='0x2'/>
    </controller>
    <controller type='pci' index='0' model='pci-root'>
      <alias name='pci.0'/>
    </controller>
      <alias name='ide'/>
    </controller>
      <alias name='virtio-serial0'/>
    </controller>
      <mac address='52:54:00:16:9f:17'/>
      <target dev='vnet0'/>
      <alias name='net0'/>
    </interface>
    <serial type='pty'>
      <source path='/dev/pts/0'/>
      <target port='0'/>
      <alias name='serial0'/>
    </serial>
    <console type='pty' tty='/dev/pts/0'>
    </console>
      <source mode='bind' path='/var/lib/libvirt/qemu/channel/target/kubutute.org.qemu.guest_agent.0'/>
      <target type='virtio' name='org.qemu.guest_agent.0' state='disconnected'/>
      <alias name='channel0'/>
    </channel>
      <alias name='input0'/>
    </input>
    <graphics type='vnc' port='5900' autoport='yes' websocket='5700' listen='0.0.0.0' keymap='en-us'>
    </graphics>
    <video>
      <alias name='video0'/>
    </video>
      <alias name='balloon0'/>
    </memballoon>
  </devices>
</domain>
here are the diagnostics
I hope it can help
Please don't put your diagnostics on an external site when they are small enough to attach directly to your post. This only creates extra trouble for people trying to help you, including possible security issues.
Syslog makes me suspect filesystem corruption on disk1. And it also shows you installing even more plugins after your boot.
My advice to you would be to start completely over, take things one at a time, ask for help about one thing at a time, only add one thing at a time, and don't even think about the next thing until you are sure you have that one thing working.
Try not pinning core 0 in any of the VMs.  Read here and see if that helps.
Thanks CHBMB
Thanks trurl
I will did what you ask me to do
and i will post update later
Hello
I did a refresh install
and format every drive  the problem now is with VNC cant connect
And it show with the wrong port when the correct it refuse to connect
Need help to fix it
Thanks
tower-diagnostics-20160624-1937.zip
