Ryan2207 Posted August 4, 2016 Share Posted August 4, 2016 Hello I was just wondering is it possible to extract the serial numbers of the hard drives in my array for reference later when one fails ? Kind Regards Ryan Link to comment
moose Posted August 4, 2016 Share Posted August 4, 2016 You should see these in the "Array Devices" section of the "Main" tab in your unRAID web GUI. I believe the serial numbers are the portion to the right of the underscore for each disk identification. Check by doing a screenshot (or take a picture of that screen with your phone) then check the sticker on top of one of the drives in your server to match the alphanumeric code of the serial number. Link to comment
