February 17, 201016 yr Looks like I need to change one more parameter UPSTYPE Currently it is set to "usb" I think it needs to be set to "apcsmart" for your serial port connection.
February 17, 201016 yr Here is an updated .zip. The unMENU package-manager plugin file AND the apcupsd-unmenu-package.conf are both updated in this zip. Now, if you edit the configuration variables the existing manual_install and auto_install files will be automatically removed. You will then be presented with button to re-install with the new values, and re-enable on re-boot with the new values. I added this line in the apc ups package configuration file: PACKAGE_INSTALLATION [ "${vDEVICE-NO}" = "YES" ] && sed -i -e "s/^UPSTYPE usb/UPSTYPE apcsmart/" /etc/apcupsd/apcupsd.conf Unzip to your /boot/unmenu folder. refresh the package-manager plug-in page to have it re-read the new files. Joe L. apcupsd-unmenu.zip
February 17, 201016 yr I updated the zip file in the prior post... Reminder to self... Make sure you have a second cup of coffee before attempting complex tasks in the AM. Joe L.
February 17, 201016 yr Author The package manager is very nice, very simple. And it seems now that everything is working. I can see the ups status from the system info page. I will experiment with it now and report back. Many thanks to getting this working for me.
February 17, 201016 yr The package manager is very nice, very simple. And it seems now that everything is working. I can see the ups status from the system info page. I will experiment with it now and report back. Many thanks to getting this working for me. Great News!!!!!!!!! Joe L.
February 17, 201016 yr Author I did and also installed the clean powerdown. I've down some simulated power outages. It shut down just like it should, and returns when power is restored. You are a major asset to the community. I really appreciate you taking the time to get this sorted out with me. A syslog is attached to show your time has paid off. syslog-2010-02-17.txt
