replacement key problems
I'm trying to replace my flash and the instructions emailed to me states, "To install the key, paste the above key file link into the Key file URL field on the webGUI Registration page and then click Install Key." My problem is that I do not see this field on my webGUI Registration page (See attachment). What do I need to do to see this?
You can always download the file from the link, and toss the file onto the flash drive (config folder) and reboot.
Not sure why you're not seeing the line though...
You'll see the line if you delete the mismatch key.
Thanks, guys.Got it working
