Ready to Start! Need help to ensure I do it right the first time!
Firstly I completely misuderstood how UnRAID works. From what I've read, UnRAID is basically JBOD + parity? I initially thought I'd just install all my drives (including parity) and just start copying my files over and that's it. But it looks like I'll have to assign shares/splits per drive and if the drive becomes full I'll have to move data around to the drive that has the most space and/or upgrade the drive itself. I guess it wouldn't be power efficient if all drives were spinning when I access a movie from the UnRAID server. Let me know if I'm not getting it...
Final specs are as follows:
1x CM Stacker 810 (E-ATX, ATX, m-ATX, BTX, m-BTX) 810
1x Corsair VX-450 ATX 450W Power Supply 120mm fan
2x OCZ 2G DDR3 800 PC3 6400MHz Gold Series
1x Intel Celeron Dual Core E3300 2.5GHZ 800FSB LGA775
1x Western Digital 2TB Green 64MB SATAII WD20EARS - Parity Drive
2x 500GB WD
2x 1TB WD
Anyway, I've compiled a list of steps to do, they are as follows:
1.Wait for all part arrivals
2.Prepare case for build. Cleaning, installation of fans, etc.
3.Build server
4.Create UnRAID OS in flash drive
5.Conduct a memory test in BIOS
6.Empty one 1TB drive and distribute files in existing system
7.Install 1TB drive and assign in UnRAID
8.Set up share to 1TB drive
9.Copy files over to UnRAID
10.Repeat steps 4 through to 7, ensuring as each drive is emptied that they are installed in the UnRAID server and correctly assigned
11.When complete, install assign the Parity Drive
12.Start the array
13.Run a manual parity check
14.Run a smartctl on each drive
15.Enjoy?
I'd appreciate it if anyone can go over these steps and see if I've missed something, need to skip something, or re-arrange the steps.
I've also got a list of add ons I plan on installing, they are:
- PowerDown (script)
- UnMenu
- UnTorrent (much later when server itself is established)
- SmartHistory
- Email Notifications
Many thanks once again!
Actually, it is exactly that, provided you use the disk shares (/mnt/disk#) instead of the user shares (/mnt/user).
Getting confused again... is that the recommended way of how they are set up? I'm not very good with linux and just plan on using the UnRAID interface in setting it up. I might go and reread the wiki and around here on the matter.  The other thing is that the 4 drives I plan on using already have data in them but I am able to move data around for now while they are in my PC and slowly empty the bigger drives first and one by one from UnRAID to format and assign the drives. When all done I will then install and assign the parity.
edit:
Ahhh, from: http://lime-technology.com/wiki/index.php?title=Building_an_unRAID_Server
"The drives are not merged into one large logical volume (or directory) Actually, they now are merged in the "user-shares" feature "
There's no "recommended way", it's a matter of personal preference.
User share gives you a unified view of your disks.  It can be messy and confusing, and it brings a signifficant overhead to the server.
Personally, I don't use user shares.  I like to know and control where my files go.  So I only use disk shares.
There are people who like it the other way.  It's up to you, really.
Excellent, that's exactly how I'm wanting to set up my shares!
Just re-reading the Building an unRAID Server wiki page: http://lime-technology.com/wiki/index.php?title=Building_an_unRAID_Server
"Shares
By default, unRAID creates a share for each disk in the array (\\tower\disk1, \\tower\disk2, etc.). This isn't usually what people want. unRAID supports the concept of User Shares. Basically, you can create folders in each of the disk shares, and then a user folder will "aggregate" all of the content from each share into one share with that folder name. So, if you have \\tower\disk1\DVD and \\tower\disk2\DVD, a user share can be created for \\tower\DVD. To turn on user shares, go to the Shares menu item. Select an option from the User Shares dropdown. If you want the shares to be read-only, select "Export read-only." In order to pick up new User Shares (or top level directories), you will need to press the "Re-scan" button. The "Re-scan" button is gone in recent releases as it is no longer necessary. Now, the user-share folders automatically update when any change is made to the disk shares.
I should just be able to structure the 'disk shares' and grant 'user' shares to those, correct?
"Shares
This isn't usually what people want..."
Sorry, but that is exactly what I want!  :)
Any decent HTPC frontend knows how to aggregate its import paths.
Who wrote that wiki entry?  ::)
"Shares
Ihave no idea who wrote it, but if you go back a few years, the network media players did not aggregate import paths, they just listed the servers, and when you clicked on a server, they listed the shared folders.  I've got two AlTech MediaGate MG-35 media players that work exactly like that and have been for almost 4 years.
Now, I've also now got a new Acer Revo 1600 running XBMC. It can do the aggregation... but older media players... no way.
I apologize for asking a queston off topic...  that's the one with the single core 230, right?
How happy are you with it?  Is browsing with XBMC snappy enough with the single core?
I still can't make my mind if I should go for the dual core version. (sorry again for asking this out of place)
Fanart lags a tiny bit, shows up in about half a second or so after I pause scanning the movie list.  otherwise, it is fine.
XBMC works similarly in my dual-core Vista based laptop, so to me it is fine.  I'm running the 9.11 live version from a USB flash drive.  Never bothered to install to the internal disk.
Thanks for the info.
