September 22, 20179 yr The card is a Inateck PCI-E to USB 3.0 5-Port PCI Express Card. It's in an isolated IOMMU group, and I've been able to assign it to the VM in the edit screen after adding the id to my syslinux config using vfio-pci.ids. After unchecking all my individual USB devices and checking the usb controller the VM hangs at start. I'm seeing an error in the VM's log as follows: qemu-system-x86_64: -device vfio-pci,host=03:00.0,id=hostdev2,bus=pci.0,addr=0x8: Failed to mmap 0000:03:00.0 BAR 2. Performance may be slow In case it helps, here's my VM's XML: <domain type='kvm' id='2'> <name>Windows 10</name> <uuid>60a9ffb5-fe56-1dfc-7f7e-538c4d390a67</uuid> <description>Gaming Desktop</description> <metadata> <vmtemplate xmlns="unraid" name="Windows 10" icon="windows.png" os="windows10"/> </metadata> <memory unit='KiB'>16777216</memory> <currentMemory unit='KiB'>16777216</currentMemory> <memoryBacking> <nosharepages/> </memoryBacking> <vcpu placement='static'>6</vcpu> <cputune> <vcpupin vcpu='0' cpuset='1'/> <vcpupin vcpu='1' cpuset='2'/> <vcpupin vcpu='2' cpuset='3'/> <vcpupin vcpu='3' cpuset='5'/> <vcpupin vcpu='4' cpuset='6'/> <vcpupin vcpu='5' cpuset='7'/> </cputune> <resource> <partition>/machine</partition> </resource> <os> <type arch='x86_64' machine='pc-i440fx-2.7'>hvm</type> </os> <features> <acpi/> <apic/> <hyperv> <relaxed state='on'/> <vapic state='on'/> <spinlocks state='on' retries='8191'/> <vendor_id state='on' value='none'/> </hyperv> </features> <cpu mode='host-passthrough'> <topology sockets='1' cores='3' threads='2'/> </cpu> <clock offset='localtime'> <timer name='hypervclock' present='yes'/> <timer name='hpet' present='no'/> </clock> <on_poweroff>destroy</on_poweroff> <on_reboot>restart</on_reboot> <on_crash>restart</on_crash> <devices> <emulator>/usr/local/sbin/qemu</emulator> <disk type='file' device='disk'> <driver name='qemu' type='raw' cache='writeback'/> <source file='/mnt/user/domains/Windows 10/vdisk1.img'/> <backingStore/> <target dev='hdc' bus='virtio'/> <boot order='1'/> <alias name='virtio-disk2'/> <address type='pci' domain='0x0000' bus='0x00' slot='0x04' function='0x0'/> </disk> <disk type='file' device='cdrom'> <driver name='qemu' type='raw'/> <source file='/mnt/user/isos/Win10_1703_English_x64.iso'/> <backingStore/> <target dev='hda' bus='ide'/> <readonly/> <boot order='2'/> <alias name='ide0-0-0'/> <address type='drive' controller='0' bus='0' target='0' unit='0'/> </disk> <disk type='file' device='cdrom'> <driver name='qemu' type='raw'/> <source file='/mnt/user/isos/virtio-win-0.1.126-2.iso'/> <backingStore/> <target dev='hdb' bus='ide'/> <readonly/> <alias name='ide0-0-1'/> <address type='drive' controller='0' bus='0' target='0' unit='1'/> </disk> <controller type='usb' index='0' model='nec-xhci'> <alias name='usb'/> <address type='pci' domain='0x0000' bus='0x00' slot='0x07' function='0x0'/> </controller> <controller type='pci' index='0' model='pci-root'> <alias name='pci.0'/> </controller> <controller type='ide' index='0'> <alias name='ide'/> <address type='pci' domain='0x0000' bus='0x00' slot='0x01' function='0x1'/> </controller> <controller type='virtio-serial' index='0'> <alias name='virtio-serial0'/> <address type='pci' domain='0x0000' bus='0x00' slot='0x03' function='0x0'/> </controller> <interface type='bridge'> <mac address='52:54:00:60:4a:e4'/> <source bridge='br0'/> <target dev='vnet0'/> <model type='virtio'/> <alias name='net0'/> <address type='pci' domain='0x0000' bus='0x00' slot='0x02' function='0x0'/> </interface> <serial type='pty'> <source path='/dev/pts/0'/> <target port='0'/> <alias name='serial0'/> </serial> <console type='pty' tty='/dev/pts/0'> <source path='/dev/pts/0'/> <target type='serial' port='0'/> <alias name='serial0'/> </console> <channel type='unix'> <source mode='bind' path='/var/lib/libvirt/qemu/channel/target/domain-2-Windows 10/org.qemu.guest_agent.0'/> <target type='virtio' name='org.qemu.guest_agent.0' state='disconnected'/> <alias name='channel0'/> <address type='virtio-serial' controller='0' bus='0' port='1'/> </channel> <input type='mouse' bus='ps2'> <alias name='input0'/> </input> <input type='keyboard' bus='ps2'> <alias name='input1'/> </input> <hostdev mode='subsystem' type='pci' managed='yes' xvga='yes'> <driver name='vfio'/> <source> <address domain='0x0000' bus='0x01' slot='0x00' function='0x0'/> </source> <alias name='hostdev0'/> <address type='pci' domain='0x0000' bus='0x00' slot='0x05' function='0x0'/> </hostdev> <hostdev mode='subsystem' type='pci' managed='yes'> <driver name='vfio'/> <source> <address domain='0x0000' bus='0x01' slot='0x00' function='0x1'/> </source> <alias name='hostdev1'/> <address type='pci' domain='0x0000' bus='0x00' slot='0x06' function='0x0'/> </hostdev> <hostdev mode='subsystem' type='pci' managed='yes'> <driver name='vfio'/> <source> <address domain='0x0000' bus='0x03' slot='0x00' function='0x0'/> </source> <alias name='hostdev2'/> <address type='pci' domain='0x0000' bus='0x00' slot='0x08' function='0x0'/> </hostdev> <memballoon model='virtio'> <alias name='balloon0'/> <address type='pci' domain='0x0000' bus='0x00' slot='0x09' function='0x0'/> </memballoon> </devices> <seclabel type='none' model='none'/> <seclabel type='dynamic' model='dac' relabel='yes'> <label>+0:+100</label> <imagelabel>+0:+100</imagelabel> </seclabel> </domain>
September 26, 20179 yr i always get a similar message - but now, not sure if when passingthrough similar card (inatek fresco), or the onboard controller asmedia 3.1 - will check and update... But the VM is ok, it boots without issues and i can work with the USB ports, plug and play... If you have any devices plugged in, try to remove them. Sometimes i got issues like this with a rii mini wireless keyboard, but not with logitech (unifying dongle). Also try various other VM guest OS's - linux mint for example, or ubuntu gnome, or fedora 25/26...
September 26, 20179 yr Author 3 hours ago, alexciurea said: i always get a similar message - but now, not sure if when passingthrough similar card (inatek fresco), or the onboard controller asmedia 3.1 - will check and update... But the VM is ok, it boots without issues and i can work with the USB ports, plug and play... If you have any devices plugged in, try to remove them. Sometimes i got issues like this with a rii mini wireless keyboard, but not with logitech (unifying dongle). Also try various other VM guest OS's - linux mint for example, or ubuntu gnome, or fedora 25/26... Thank you so much! I unplugged everything from the controller except my logitech unifying dongle and it booted as it should. I reconnected my xbox wireless adapter and that still worked too. Now I'm having problems with my logitech g933 headset, but that's a different issue. Thanks again for the suggestion!
September 27, 20179 yr welcome my next suggestion would have been to try with a fresh restart of entire unraid server. I got a similar issue when trying to install ubuntu 14.04. After restart of unraid (so all usb's were "fresh", without any leftovers from previous connections) i was able to boot and install the ubuntu 14.04. good luck!
October 3, 20179 yr Just a note, in my travels I found that fresco logic usb3 cards have really nasty reset issues. I'd recommend a different card if that is the chipset yours uses.
October 5, 20179 yr i did not encounter stability issues with the plugged devices. also i am switching the unifying receiver from one controller to another (the controllers are passed through to different VM's) and no issue. USB sticks, HDD, speedlink wireless controllers - all went ok... The only issue i faced sometimes, as mentioned earlier, was with a rii mini keyboard usb dongle, when plugged in to an asmedia 3.1 internal controller - from time to time, it makes the controller to freeze or something, and i need to reset the whole unraid box...
October 6, 20179 yr Just a note, in my travels I found that fresco logic usb3 cards have really nasty reset issues. I'd recommend a different card if that is the chipset yours uses.Can also confirm this. Sent from my iPad using Tapatalk
