November 3, 20179 yr What exactly does the message Reboot will activate a clean system reset mean? I have been fooling around with a controller that has the parity attached, after which I started a parity check which seemed to run ok, but was cancelled by me. What exactly triggers the earlier mentioned message?The server runs 6.3.5.
November 3, 20179 yr It means the Reboot command issues a Stop Services and Stop Array action first before rebooting. Stopping the services and the array must be completed within 90 seconds (time is configurable) before reboot kicks in, otherwise a unclear reboot happens.
