January 29, 20188 yr Hi there, I replaced a 2 TB drive yesterday with a 4 TB drive, I powered down the server replaced the drive and once the server was up I chose the new drive in the old drives position and started the rebuild then I saw a message that it was unmountable and it gave me an option to format the drive which I did, I aborted the existing parity resync and started it again. It now finished but there is no data on the drive and it shows a utilization of 4 gb. Luckily I still have the original drive as it did not fail, but what did I do wrong here? I have attached my diagnostic file tower-diagnostics-20180129-0742.zip
January 29, 20188 yr 1 hour ago, MrLondon said: but what did I do wrong here? 1 hour ago, MrLondon said: it gave me an option to format the drive which I did Formatting is never part of a rebuild, it deletes all data on the disk and it updates parity.
January 29, 20188 yr You can mount the old disk with the UD plugin and copy the data to the new disk.
