Unoid Posted April 11, 2018 Share Posted April 11, 2018 Today I noticed my power flickered and my unraid UPS cycled on temporarily. Then my Unraid USB drive became unresponsive. I wrote down some syslog problems and did a reboot thinking it'd come back, but it isn't. I popped the USB stick into my win10 box and the files seems intact. Any ideas? I do have backups of the USB stick but they're on one of my disks in my unraid server. Would have to pop one out mount on windows/linux?, and try to reformat the USB stick and copy old files back. EDIT: Plugged a monitor into my server. It does boot off the USB and if I pick the default Unraid OS, it stalls at the first step of reading /bzimage EDIT 2: Trying to boot again and it only says: SYSLINUX 6.03 EDDBoot error Apr 11 12:06:51 Tower kernel: usb 2-1.2: USB disconnect, device number 3 Apr 11 12:06:52 Tower kernel: usb 2-1.2: new full-speed USB device number 4 using ehci-pci Apr 11 12:06:52 Tower kernel: hid-generic 0003:0764:0501.0002: hiddev96,hidraw0: USB HID v1.10 Device [CPS CP1350PFCLCD] on usb-0000:00:1d.0-1.2/input0 Apr 11 12:06:53 Tower kernel: xhci_hcd 0000:03:00.0: Cannot set link state. Apr 11 12:06:53 Tower kernel: usb usb4-port2: cannot disable (err = -32) Apr 11 12:06:53 Tower kernel: xhci_hcd 0000:03:00.0: Cannot set link state. Apr 11 12:06:53 Tower kernel: usb usb4-port2: cannot disable (err = -32) Apr 11 12:06:53 Tower kernel: usb 4-2: USB disconnect, device number 2 Apr 11 12:06:53 Tower kernel: sd 0:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x01 driverbyte=0x00 Apr 11 12:06:53 Tower kernel: sd 0:0:0:0: [sda] tag#0 CDB: opcode=0x28 28 00 00 16 d9 70 00 00 40 00 Apr 11 12:06:53 Tower kernel: print_req_error: I/O error, dev sda, sector 1497456 Apr 11 12:06:53 Tower kernel: sd 0:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x01 driverbyte=0x00 Apr 11 12:06:53 Tower kernel: sd 0:0:0:0: [sda] tag#0 CDB: opcode=0x28 28 00 00 16 d9 b0 00 00 80 00 Apr 11 12:06:53 Tower kernel: print_req_error: I/O error, dev sda, sector 1497520 Apr 11 12:06:53 Tower kernel: print_req_error: I/O error, dev loop0, sector 15008 Apr 11 12:06:53 Tower kernel: SQUASHFS error: squashfs_read_data failed to read block 0x74fa5c Apr 11 12:06:53 Tower kernel: SQUASHFS error: Unable to read fragment cache entry [74fa5c] Apr 11 12:06:53 Tower kernel: SQUASHFS error: Unable to read page, block 74fa5c, size 159e4 Apr 11 12:06:53 Tower kernel: print_req_error: I/O error, dev loop0, sector 15010 Apr 11 12:06:53 Tower kernel: SQUASHFS error: Unable to read fragment cache entry [74fa5c] Apr 11 12:06:53 Tower kernel: SQUASHFS error: Unable to read page, block 74fa5c, size 159e4 Apr 11 12:06:53 Tower kernel: print_req_error: I/O error, dev loop0, sector 15012 Apr 11 12:06:53 Tower kernel: SQUASHFS error: Unable to read fragment cache entry [74fa5c] Apr 11 12:06:53 Tower kernel: SQUASHFS error: Unable to read page, block 74fa5c, size 159e4 Apr 11 12:06:53 Tower kernel: SQUASHFS error: Unable to read fragment cache entry [74fa5c] Apr 11 12:06:53 Tower kernel: print_req_error: I/O error, dev loop0, sector 15014 Apr 11 12:06:53 Tower kernel: SQUASHFS error: Unable to read page, block 74fa5c, size 159e4 Apr 11 12:06:53 Tower kernel: SQUASHFS error: Unable to read fragment cache entry [74fa5c] Apr 11 12:06:53 Tower kernel: SQUASHFS error: Unable to read page, block 74fa5c, size 159e4 Apr 11 12:06:53 Tower kernel: print_req_error: I/O error, dev loop0, sector 15016 Apr 11 12:06:53 Tower kernel: SQUASHFS error: Unable to read fragment cache entry [74fa5c] Apr 11 12:06:53 Tower kernel: SQUASHFS error: Unable to read page, block 74fa5c, size 159e4 Apr 11 12:06:53 Tower kernel: print_req_error: I/O error, dev loop0, sector 15018 Apr 11 12:06:53 Tower kernel: print_req_error: I/O error, dev loop0, sector 15020 Apr 11 12:06:53 Tower kernel: print_req_error: I/O error, dev loop0, sector 15022 Apr 11 12:06:53 Tower kernel: SQUASHFS error: squashfs_read_data failed to read block 0x3f5d8c Apr 11 12:06:53 Tower kernel: SQUASHFS error: squashfs_read_data failed to read block 0x3f5d8c Apr 11 12:06:53 Tower kernel: blk_partition_remap: fail for partition 1 Apr 11 12:06:54 Tower kernel: FAT-fs (sda1): Directory bread(block 324928) failed Link to comment
Unoid Posted April 11, 2018 Author Share Posted April 11, 2018 Well, this is weird. I moved where the plug the USB stick into and it had more errors, I fiddled with how it was plugged in and magically it's booting again now. Doens't make much sense. I'm going to backup the USB stick again and buy a replacement. I suppose I don't need help anymore Link to comment
