April 30, 20188 yr I have a user script. I would like to run it after a docker container starts. It doesn't work if I schedule it "At startup of array", as the script tries to run before the container starts. What is the best way to run a script after a specific docker container starts? Thanks. Edited April 30, 20188 yr by sse450
May 8, 20188 yr How often are you restarting the docker that you need this? Also what is the actual thing you are trying to do? I would created a bash file in the app data stored folder so it survives re-installs. I then created a file like attached with a variety of command that I want to execute on some of my containers. You would still need to use the command line to execute the menu script. im sure there are other ways to do what you want as well. menu
