August 5, 20188 yr Hi guys, I have two things, that don't work after switching to another machine. I was moving everything from a Dell T20 with Xeon E3 1225 V3 to a HP Compaq Elite 8300 with i5 3570. Unfortunately the system devices overview is still showing the old hardware. What can I do to change this? Does it harm the whole system if it is like that? Everything seems to work as normal, including VMs. Additionally I wanted to see if I can get rid of the UDMA CRC Errors (2 WD Red 3TB, one with 422 errors (Parity drive on SATA 0 in both computers) one with 220 errors (Array drive on SATA 1 in both computers) with the transfer I changed cables multiple times I took off the cable binders as I thought it could be shielding problem I thought it could be the hard drive cage, but after testing it over night on SATA2 and SATA3 with the hard drives in the cage, no errors at all. -.- I doubt, that my new DELL T20 was having hardware issues on both SATA ports 0,1 same like the board I switched to now. Might there be a chance that the WD Red Controllers only produce theses failures on the SATA 3 ports (0,1) and not on the SATA 2 ports (2,3) and it is a WD problem? System devices IOMMU group 0: [8086:0150] 00:00.0 Host bridge: Intel Corporation Xeon E3-1200 v2/3rd Gen Core processor DRAM Controller (rev 09) IOMMU group 1: [8086:0152] 00:02.0 VGA compatible controller: Intel Corporation Xeon E3-1200 v2/3rd Gen Core processor Graphics Controller (rev 09) IOMMU group 2: [8086:1e31] 00:14.0 USB controller: Intel Corporation 7 Series/C210 Series Chipset Family USB xHCI Host Controller (rev 04) IOMMU group 3: [8086:1e3a] 00:16.0 Communication controller: Intel Corporation 7 Series/C216 Chipset Family MEI Controller #1 (rev 04) [8086:1e3d] 00:16.3 Serial controller: Intel Corporation 7 Series/C210 Series Chipset Family KT Controller (rev 04) IOMMU group 4: [8086:1502] 00:19.0 Ethernet controller: Intel Corporation 82579LM Gigabit Network Connection (Lewisville) (rev 04) IOMMU group 5: [8086:1e2d] 00:1a.0 USB controller: Intel Corporation 7 Series/C216 Chipset Family USB Enhanced Host Controller #2 (rev 04) IOMMU group 6: [8086:1e20] 00:1b.0 Audio device: Intel Corporation 7 Series/C216 Chipset Family High Definition Audio Controller (rev 04) IOMMU group 7: [8086:1e26] 00:1d.0 USB controller: Intel Corporation 7 Series/C216 Chipset Family USB Enhanced Host Controller #1 (rev 04) IOMMU group 8: [8086:244e] 00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev a4) IOMMU group 9: [8086:1e47] 00:1f.0 ISA bridge: Intel Corporation Q77 Express Chipset LPC Controller (rev 04) [8086:1e02] 00:1f.2 SATA controller: Intel Corporation 7 Series/C210 Series Chipset Family 6-port SATA Controller [AHCI mode] (rev 04) [8086:1e22] 00:1f.3 SMBus: Intel Corporation 7 Series/C216 Chipset Family SMBus Controller (rev 04) HDD information of parity drive no connected on SATA port 2 Aug 4 17:13:15 unRAID kernel: ata4: SATA max UDMA/133 abar m2048@0xf7c36000 port 0xf7c36280 irq 27Aug 4 17:13:15 unRAID kernel: ata4: SATA link up 3.0 Gbps (SStatus 123 SControl 300)Aug 4 17:13:15 unRAID kernel: ata4.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeededAug 4 17:13:15 unRAID kernel: ata4.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered outAug 4 17:13:15 unRAID kernel: ata4.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered outAug 4 17:13:15 unRAID kernel: ata4.00: ATA-9: WDC WD30EFRX-68EUZN0, WD-(WD SERIAL HERE), 82.00A82, max UDMA/133Aug 4 17:13:15 unRAID kernel: ata4.00: 5860533168 sectors, multi 16: LBA48 NCQ (depth 31/32), AAAug 4 17:13:15 unRAID kernel: ata4.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeededAug 4 17:13:15 unRAID kernel: ata4.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered outAug 4 17:13:15 unRAID kernel: ata4.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered outAug 4 17:13:15 unRAID kernel: ata4.00: configured for UDMA/133Aug 4 17:13:15 unRAID kernel: sd 4:0:0:0: [sdc] 5860533168 512-byte logical blocks: (3.00 TB/2.73 TiB)Aug 4 17:13:15 unRAID kernel: sd 4:0:0:0: [sdc] 4096-byte physical blocksAug 4 17:13:15 unRAID kernel: sd 4:0:0:0: [sdc] Write Protect is offAug 4 17:13:15 unRAID kernel: sd 4:0:0:0: [sdc] Mode Sense: 00 3a 00 00Aug 4 17:13:15 unRAID kernel: sd 4:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUAAug 4 17:13:15 unRAID kernel: sdc: sdc1Aug 4 17:13:15 unRAID kernel: sd 4:0:0:0: [sdc] Attached SCSI diskAug 4 17:13:20 unRAID emhttpd: WDC_WD30EFRX-68EUZN0_WD-(WD SERIAL HERE) (sdc) 512 5860533168Aug 4 17:13:20 unRAID kernel: mdcmd (1): import 0 sdc 64 2930266532 0 WDC_WD30EFRX-68EUZN0_WD-(WD SERIAL HERE)Aug 4 17:13:20 unRAID kernel: md: import disk0: (sdc) WDC_WD30EFRX-68EUZN0_WD-(WD SERIAL HERE) size: 2930266532Aug 4 17:13:20 unRAID emhttpd: shcmd (25): /usr/local/sbin/set_ncq sdc 1Aug 4 17:13:20 unRAID root: set_ncq: setting sdc queue_depth to 1Aug 4 17:13:20 unRAID emhttpd: shcmd (26): echo 128 > /sys/block/sdc/queue/nr_requestsAug 4 17:14:50 unRAID emhttpd: shcmd (123): /usr/local/sbin/set_ncq sdc 1Aug 4 17:14:50 unRAID emhttpd: shcmd (124): echo 128 > /sys/block/sdc/queue/nr_requestsAug 4 17:15:06 unRAID emhttpd: shcmd (144): /usr/local/sbin/set_ncq sdc 1Aug 4 17:15:06 unRAID emhttpd: shcmd (145): echo 128 > /sys/block/sdc/queue/nr_requests Thanks all!
August 5, 20188 yr Community Expert 1 hour ago, xtiang7c0 said: Unfortunately the system devices overview is still showing the old hardware. This is not possible, you're seeing the new system info, if you think so by seeing Xeon mentioned it's normal, it mentions both: Quote Intel Corporation Xeon E3-1200 v2/3rd Gen Core processor DRAM Controller 1 hour ago, xtiang7c0 said: Additionally I wanted to see if I can get rid of the UDMA CRC Errors You can't, UDMA CRC errors never reset, you can acknowledge them and as long as they don't increase the problem is fixed.
