September 20, 20188 yr Hello I want to setup unraid on my windows server 2016 with hyper-v, but after unraid is installed it can't find the nic. it does have an IP from the APIPA protocol, but even when I set the ip and the gateway manually I can't connect to it. does anybody have a idea?
October 14, 20188 yr If the driver isn't in the kernel you won't be able to use it. Also if you don't somehow have the usb stick "plugged in" to hyper-v it won't matter as the license key won't read. I've been down many roads sadly..
