Fix Common Problems Machine Check Events
Fix common problems has a machine check events detected on your system.
I have attached the diagnostic report from the system.
I am running a AMD Ryzen and it seem that the mcelog is not supported by this processor and the other option mentioned in the syslogs is not found in Nerd Pack. Any idea how to get edac_mce_amd?
`mcelog: ERROR: AMD Processor family 23: mcelog does not support this processor.  Please use the edac_mce_amd module instead.`
tower-diagnostics-20190621-1533.zip
Here's the MCE  not sure what to do though, if its even a problem.  Google may be your friend / acquaintance
Jun  5 18:23:36 Tower kernel: mce: [Hardware Error]: Machine check events logged
Jun  5 18:23:36 Tower kernel: [Hardware Error]: Corrected error, no action required.
Jun  5 18:23:36 Tower kernel: [Hardware Error]: CPU:5 (17:1:1) MC1_STATUS[-|CE|MiscV|-|-|-|-|SyndV|-]: 0x98200000000b0151
Jun  5 18:23:36 Tower kernel: [Hardware Error]: IPID: 0x000100b000000000, Syndrome: 0x000000004a000000
Jun  5 18:23:36 Tower kernel: [Hardware Error]: Instruction Fetch Unit Extended Error Code: 11
Jun  5 18:23:36 Tower kernel: [Hardware Error]: Instruction Fetch Unit Error: L2 BTB multi-match error.
Jun  5 18:23:36 Tower kernel: [Hardware Error]: cache level: L1, tx: INSN, mem-tx: IRD
Thanks, I will see what Google has to say.
