September 13, 20197 yr I'm using this XMLRPC-Client to send "Start/Stop downloads" commands from Tautulli to another Unraid docker container: https://gist.github.com/bjoern-r/c3afda16d45edad5f4a5 The last two lines of this script look like this: curl -k $verbose --data "@$rpcxml" "$servUrl" 2>/dev/null | xmllint --format - \rm -f $rpcxml xmllint is not part of Unraid so I removed the pipe: curl -k $verbose --data "@$rpcxml" "$servUrl" 2>/dev/null \rm -f $rpcxml I was under the impression, that "\rm $rpcxml" would remove the temporary xml file in $rpcxml. That does not work. Every RPC request leaves the temp file in the directory. Any help is highly appreciated. Edited September 13, 20197 yr by hawihoney
