January 21, 20206 yr I know this is a simple thing to do, but I can't figure it out. I accidentally pulled one of my array drives out (hotswap) while it was running. I was trying to pull another drive out that was an unassigned drive. Now I can't figure out how to add that drive back. I've pulled the drive and put it back (unassigned sees it) , restarted unraid, stopped the array, only thing I seen was to change the drive. Only problem is that I don't have an extra 8tb drive available to swap. Last time (by accident) I pulled a drive, it was a 4tb and I had a spare. I just swapped it and it rebuilt. Please let me know if there is anything I can do to put the same drive back. Thank you in advance.
January 21, 20206 yr https://wiki.unraid.net/Troubleshooting#Re-enable_the_drive Make sure emulated disk is mounting correctly before rebuilding on top.
