March 17, 20206 yr Fix Common Problems is saying i have hard ware errors and to attache my diagnostic file here. Anyone that can tell me what the errors are so I can work on fixing them I would appreciate it. plexserver-diagnostics-20200317-0952.zip
March 17, 20206 yr Bad memory Mar 15 11:20:16 PlexServer kernel: EDAC sbridge MC0: HANDLING MCE MEMORY ERROR Mar 15 11:20:16 PlexServer kernel: EDAC sbridge MC0: CPU 0: Machine Check Event: 0 Bank 9: 8c000047000800c1 Mar 15 11:20:16 PlexServer kernel: EDAC sbridge MC0: TSC c4dba98dd7d33 Mar 15 11:20:16 PlexServer kernel: EDAC sbridge MC0: ADDR 548773000 Mar 15 11:20:16 PlexServer kernel: EDAC sbridge MC0: MISC 900080008000e8c Mar 15 11:20:16 PlexServer kernel: EDAC sbridge MC0: PROCESSOR 0:206d7 TIME 1584292816 SOCKET 0 APIC 0 Mar 15 11:20:16 PlexServer kernel: EDAC MC0: 1 CE memory scrubbing error on CPU_SrcID#0_Ha#0_Chan#1_DIMM#0 (channel:1 slot:0 page:0x548773 offset:0x0 grain:32 syndrome:0x0 - area:DRAM err_code:0008:00c1 socket:0 ha:0 channel_mask:2 rank:0) You system event log may have more information on which stick in particular over the description of channel 1, dimm 0
March 17, 20206 yr @Jurak From plexserver-diagnostics.zip ==> logs ==> syslog Quote Mar 14 19:36:24 PlexServer kernel: mce: [Hardware Error]: Machine check events logged Mar 14 19:36:24 PlexServer kernel: EDAC sbridge MC0: HANDLING MCE MEMORY ERROR Mar 14 19:36:24 PlexServer kernel: EDAC sbridge MC0: CPU 0: Machine Check Event: 0 Bank 5: 8c00004000010091 Mar 14 19:36:24 PlexServer kernel: EDAC sbridge MC0: TSC be6f927362a25 Mar 14 19:36:24 PlexServer kernel: EDAC sbridge MC0: ADDR 548773c80 Mar 14 19:36:24 PlexServer kernel: EDAC sbridge MC0: MISC 204050d086 Mar 14 19:36:24 PlexServer kernel: EDAC sbridge MC0: PROCESSOR 0:206d7 TIME 1584236184 SOCKET 0 APIC 0 Mar 14 19:36:24 PlexServer kernel: EDAC MC0: 1 CE memory read error on CPU_SrcID#0_Ha#0_Chan#1_DIMM#0 (channel:1 slot:0 page:0x548773 offset:0xc80 grain:32 syndrome:0x0 - area:DRAM err_code:0001:0091 socket:0 ha:0 channel_mask:2 rank:0) Looks like memory, attach peripherals and run memtest at boot, if you're unfamiliar there is an image of the boot screen here. You can also check the system event logs in the BIOS for more information. Here is a recent discussion on the matter
March 17, 20206 yr Just now, Dissones4U said: run memtest at boot, ECC Memory, so memtest won't show any error as it'll be corrected.
March 17, 20206 yr 1 minute ago, Squid said: ECC Memory, so memtest won't show any error as it'll be corrected Damn! well I'm getting a litter better at reading these things anyway...
March 17, 20206 yr 13 minutes ago, Dissones4U said: Damn! well I'm getting a litter better at reading these things anyway... Any memory error that's explicitly mentioned in a syslog means that its ECC (otherwise it couldn't detect it). And unless you're either lucky (or very unlucky depending upon your viewpoint), Memtest won't catch the problem as it'll be corrected. Only if the stick is bad enough that it doesn't catch it will memtest show anything
March 17, 20206 yr Author Thank you Squid and Dissones4U for the info. I will look into those logs once I have a chance.
