Need for Speed (Seedbox to NAS)
Hey all,
Anyone have any suggestions to maximize download speeds from an out of country seedbox to a U.S. based NAS?
I have previously used lftp due to its segmented/parallel downloads, but this is cumbersome to setup and maintain.
I have seen Syncthing and other alternatives, but have heard complaints of speed and I'd like to max out my gigabit connection when I am downloading.
I'm looking for a watch folder on the NAS to be synced to the seedbox and then the download folder on the seedbox to be synced to the NAS. Ideally, with the file being removed from the source after sync.
Any ideas? Is lftp still the best option?
Thanks in advance.
resilio sync docker.
You're able to max out download speeds and it is pretty responsive on the watch folders?
Looks like it is $60, most of the reviews are outdated or not applicable, but would be worth it if I can find a more easily manageable solution.
there's a free tier which is what i use.
Im using for backups between my server and a remote server. The files appear on the backup server very quickly.
