Is there no hope for USB devices on an ITX motherboard? Cracking audio on DAC, error 10016 for Vive Cosmos, etc.
Hi All,
I'm currently running two VMs, Manjaro for my main OS and Windows for gaming and VR.
I have a couple of USB devices that, while working, are very inconsistent and fiddly.
1) HyperX 7.1 usb soundcard - surprisingly no issues at all. I wonder why!
2) Schiit Audio DAC - constant crackling sound
3) HTC Vive Cosmos - crashing with error 10016
The application-specific permission settings do not grant Local Activation permission for the COM Server application with CLSID <id here> and APPID
<app id here> to the user <user id here> from address LocalHost (Using LRPC) running in the application container Unavailable SID (Unavailable). This security permission can be modified using the Component Services administrative tool.
While the general fix seems to be to pass through an entire usb controller, I unfortunately am unable to do that as I only have one PCI-E slot that houses my gpu.
Has anyone been able to fix some of the issues above without a usb controller? Or, sigh, should I just buy a new case and atx motherboard.
Thanks for taking the time to read my post.
Cheers,
Rj
Edited by rjbernaldo
Can you post your iommu group ?
Try this
Envoyé de mon HD1913 en utilisant Tapatalk
I only have one usb controller on my gigabyte z390 motherboard...
root@Ein:~# lspci
00:00.0 Host bridge: Intel Corporation 8th Gen Core 8-core Desktop Processor Host Bridge/DRAM Registers [Coffee Lake S] (rev 0d)
00:01.0 PCI bridge: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor PCIe Controller (x16) (rev 0d)
00:02.0 VGA compatible controller: Intel Corporation UHD Graphics 630 (Desktop 9 Series) (rev 02)
00:12.0 Signal processing controller: Intel Corporation Cannon Lake PCH Thermal Controller (rev 10)
00:14.0 USB controller: Intel Corporation Cannon Lake PCH USB 3.1 xHCI Host Controller (rev 10)
00:14.2 RAM memory: Intel Corporation Cannon Lake PCH Shared SRAM (rev 10)
00:16.0 Communication controller: Intel Corporation Cannon Lake PCH HECI Controller (rev 10)
00:17.0 SATA controller: Intel Corporation Cannon Lake PCH SATA AHCI Controller (rev 10)
00:1c.0 PCI bridge: Intel Corporation Cannon Lake PCH PCI Express Root Port #6 (rev f0)
00:1c.6 PCI bridge: Intel Corporation Cannon Lake PCH PCI Express Root Port #7 (rev f0)
00:1d.0 PCI bridge: Intel Corporation Cannon Lake PCH PCI Express Root Port #9 (rev f0)
00:1f.0 ISA bridge: Intel Corporation Z390 Chipset LPC/eSPI Controller (rev 10)
00:1f.3 Audio device: Intel Corporation Cannon Lake PCH cAVS (rev 10)
00:1f.4 SMBus: Intel Corporation Cannon Lake PCH SMBus Controller (rev 10)
00:1f.5 Serial bus controller [0c80]: Intel Corporation Cannon Lake PCH SPI Controller (rev 10)
00:1f.6 Ethernet controller: Intel Corporation Ethernet Connection (7) I219-V (rev 10)
01:00.0 VGA compatible controller: NVIDIA Corporation GM200 [GeForce GTX 980 Ti] (rev a1)
01:00.1 Audio device: NVIDIA Corporation GM200 High Definition Audio (rev a1)
02:00.0 Ethernet controller: Intel Corporation I211 Gigabit Network Connection (rev 03)
03:00.0 Network controller: Intel Corporation Dual Band Wireless-AC 3168NGW [Stone Peak] (rev 10)
04:00.0 Non-Volatile memory controller: Micron/Crucial Technology P1 NVMe PCIe SSD (rev 03)
Ah OK maybe it's not possible. Maybe if you have a gpu Witherspoon usb contrôler on it.
Appreciate the response nonetheless.
Maybe this if you have a m.2
#Aliexpress € 32,00 10%OFF | M.2 NGFF NVMe KeyM 2230 2242 2260 2280 à PCI-e 16x câble de carte Riser 1FT 2FT pci-express x16 Extender PCIe M key Gen3.0 32G/bps
https://a.aliexpress.com/_dU3p4mf
Thanks @rachid596, I do have m.2, but it's currently occupied by a 1tb ssd unfortunately. So just looking for fixes in the software side right now.
OK good luck
