Jump to content
  • [6.9.2] URGENT: does not accept " in the comment field of disk info
    Leonardo Opitz
    • Retest Minor
    Hello,
    I just did a change in the disk and add a comment:
    2,5" disk of 5 TB.
    The " (quotes) just broke the php and now I am getting the screen attached:
    I notice that state/disks.ini has that info, but looks like the file is updated from somewhere.
    If I try to change the file to fix the problem, it gets rewritten almost immediately...
    So, I really need a help here. Thanks!
    Leonardo Opitz
    PS: My copy is registered. It is the basic and in my name.
    User Feedback
    Recommended Comments
    Add a comment...
      Only 75 emoji are allowed.
  • Status Definitions
    Open = Under consideration.
    Solved = The issue has been resolved.
    Solved version = The issue has been resolved in the indicated release version.
    Closed = Feedback or opinion better posted on our forum for discussion. Also for reports we cannot reproduce or need more information. In this case just add a comment and we will review it again.
    Retest = Please retest in latest release.
    Priority Definitions
    Minor = Something not working correctly.
    Urgent = Server crash, data loss, or other showstopper.
    Annoyance = Doesn't affect functionality but should be fixed.
    Other = Announcement or other non-issue.
  • Create New...
