Jump to content
  • Clear/rebuild operations are reported as the last parity check and with the wrong avg speed if drive is smaller than parity
    JorgeB
    • Minor
    This is an old one and a twofer:
    1-After a clear or rebuild operation finishes it's report as the last parity check.
    2-If the device is smaller than parity, avg speed will be wrong, it's calculated based on parity size instead of the cleared/rebuilt device size.
    User Feedback
    Recommended Comments
    After a long wait, I made the necessary fix for this (together with some other enhancements). Should be available in the next rc of 6.10.
    • Like 3
    Link to comment
    Nice, also like that it now reports was was done, sync, check or rebuild, would it be too much to ask to also report if the parity check or correcting or non correct?
    Link to comment
    I'll have a look
    • Like 1
    Link to comment
    Add a comment...
      Only 75 emoji are allowed.
  • Status Definitions
    Open = Under consideration.
    Solved = The issue has been resolved.
    Solved version = The issue has been resolved in the indicated release version.
    Closed = Feedback or opinion better posted on our forum for discussion. Also for reports we cannot reproduce or need more information. In this case just add a comment and we will review it again.
    Retest = Please retest in latest release.
    Priority Definitions
    Minor = Something not working correctly.
    Urgent = Server crash, data loss, or other showstopper.
    Annoyance = Doesn't affect functionality but should be fixed.
    Other = Announcement or other non-issue.
  • Create New...
