February 14, 20215 yr Today my NAS started to behave strangely: - I could not add magnet links to my qbittorrent docker anymore from another machine - Unraid shares mounted on a raspberry pi suddenly were not accessible anymore and then I could not access the Unraid GUI anymore via my Firefox (and neither using any other browser or other device). I still could telnet into the machine so I first rebooted and when that did not make any difference I powerde the machine off ("Poweroff") and restarted. And that is where I am: I still can telnet onto the machine but the GUI does not start and - due to the reboot - I can't axccess any shares (don't even know whether this is possible). I am running Unraid 6.8.3. Any help would be very much appreciated.
February 14, 20215 yr Can you attach your diagnostics in your next post ? Since you cannot access the WebUI, you can type diagnostics in a terminal and it will create the file on the USB key.
February 14, 20215 yr Author Absolutely - please find attached. And thank you.nas-diagnostics-20210214-2005.zip
February 17, 20215 yr Do you know why you have this in the go file? ### Fix plugins cp -r /usr/local/emhttp/plugins/webGui/phaze.page /usr/local/emhttp/plugins/dynamix If unrelated try redoing your flash drive, backup current one, redo it, restore only super.dat (disk assignments) and the key, if it works reconfigure the server or restore older config part by part until you find the problem.
February 18, 20215 yr Author Did as asked (only restored super.dat) - the NAS booted into the Gui without a hitch. Now I wanted to force the issue (find out whether the problem was actually located somewhere in the config at all) and restored the whole config: The NAS booted into the GUI without a hitch with absolutely no harm done to it whatsoever. I mean, wtf? But thanks anyway, at least it runs again.😉
