terminaldawn Posted February 20, 2011 Share Posted February 20, 2011 Which is recommended to go with Split Level or High Water. I am reading over the Unraid manual and I am not sure which to chose.... http://www.lime-technology.com/wiki/index.php?title=UnRAID_Manual#Users They each seem to have their advantages. If I did go Split Level it would be set to 2 considering my media layout would be. Media >Movies >>MovieName >>>Movie Files Media >TV >>TVShowName >>>Season The only thing I worry about is the other shares I set up for documents etc.. Can I set up a different split level per share? Or Can I set it to hight water... Thanks! Link to comment
jamerson9 Posted February 20, 2011 Share Posted February 20, 2011 Here, try the explanation in the unofficial manual its much clearer with some very good examples that are close to what you are trying to do. http://www.lime-technology.com/wiki/index.php?title=Un-Official_UnRAID_Manual#User_shares_2 Link to comment
BRiT Posted February 20, 2011 Share Posted February 20, 2011 You might be a little confused. You use both split-level and allocation method since they serve different purposes. Split level defines the highest level in the share directory hierarchy which can be split among multiple disks. The allocation method set determines which drive will be picked. Your available allocation method choices are: High Water, Most Free, Fill-Up. Link to comment
terminaldawn Posted February 20, 2011 Author Share Posted February 20, 2011 Your available allocation method choices are: High Water, Most Free, Fill-Up. Thanks, I didn't realize this. What is typically recommended between High Water, Most Free, Fill-up? Link to comment
Joe L. Posted February 20, 2011 Share Posted February 20, 2011 Your available allocation method choices are: High Water, Most Free, Fill-Up. Thanks, I didn't realize this. What is typically recommended between High Water, Most Free, Fill-up? That too depends on personal preference. Joe L. Link to comment
