mat92910 Posted June 17, 2021 Share Posted June 17, 2021 I just got a HP NC522SFP Dual Port NIC 468349-001 from a friend and tried to install it to my NAS replacing a 1 port 10G nic I used to have in there, but i cannot select it in the network settings. I have checked in system devices and the card is showing. Do I need to install drivers for this card or is there another fix or am I stuck putting my old card back in. diagnostics.zip Quote Link to comment
JorgeB Posted June 17, 2021 Share Posted June 17, 2021 Jun 16 19:11:25 Ruskin kernel: netxen_nic 0000:08:00.0: Flash fw[4.0.406] is < min fw supported[4.0.505]. Please update firmware on flash You need to update the firmware for the driver to support the NICs. Quote Link to comment
mat92910 Posted June 17, 2021 Author Share Posted June 17, 2021 10 hours ago, JorgeB said: Jun 16 19:11:25 Ruskin kernel: netxen_nic 0000:08:00.0: Flash fw[4.0.406] is < min fw supported[4.0.505]. Please update firmware on flash You need to update the firmware for the driver to support the NICs. Do you know how i would go about updating the firmware using unraid? Quote Link to comment
JorgeB Posted June 17, 2021 Share Posted June 17, 2021 Sorry, never used one of those NICs, it shouldn't be difficult to find out by googling it, if there's no easy way with Unraid there should be with DOS/Windows. Quote Link to comment
