trurl Posted December 17, 2021 Share Posted December 17, 2021 Looks like those have happened 3 times since rebuild began. You can see them yourself in syslog. These were all on parity. Since you also have parity2 it shouldn't affect the rebuild results, and it seems to recover each time. Do you see any counts in Errors column on Main - Array Devices? Quote Link to comment
nsp24 Posted December 17, 2021 Author Share Posted December 17, 2021 yes I've seen them in the Syslog no errors reported on the Main array screen, I will let it run and if it does not crash again I will report the outcome tomorrow. Quote Link to comment
nsp24 Posted December 18, 2021 Author Share Posted December 18, 2021 Ok so the data rebuild has finished and its saying completed with no errors but on the main screan Parity 1 is saying 125 errors. looking at the sys log there are a load of read errors on disk0 Also that annoying "lost interrupt" message appeared again. Dec 17 22:38:13 Tower kernel: ata2: lost interrupt (Status 0x50) Please advise what to do the server seam to be working fine and I'm moving files around again which is what I was trying to do when I started having problems. tower-diagnostics-20211218-0552.zip Quote Link to comment
JorgeB Posted December 18, 2021 Share Posted December 18, 2021 Those errors still look like a connection/power problem. Quote Link to comment
nsp24 Posted December 18, 2021 Author Share Posted December 18, 2021 4 minutes ago, JorgeB said: Those errors still look like a connection/power problem. ok, do you know which drive has the errors is it Parity 1? on the main screen it says 125 errors on that drive. Quote Link to comment
nsp24 Posted December 18, 2021 Author Share Posted December 18, 2021 Ok so due to the errors and the possibility it was a cable or power issue I decided to swap the Motherboard as I had one I had taken out of my windows Machine I have also ordered a new PSU which is coming tomorrow which will have plenty of Sata power connectors. Now I dont really know what I'm looking for but the Syslog seems a lot better to me the only thing I have not set up at the moment is the Cache drive as I need to read up on setting that up, I will attach the file and please let me know if there is any issues. Can I just say thank you for all the help!! tower-diagnostics-20211218-1629.zip Quote Link to comment
trurl Posted December 18, 2021 Share Posted December 18, 2021 Better if you had installed cache before enabling Docker and VM Manager. You will have to disable those, set appdata, domains, system shares to cache-prefer, and run mover to get those moved to cache. When those shares are on the array disks can't spindown because the files are always open, and docker/VM performance is impacted by slower array. Quote Link to comment
