(SOLVED - Faulty Card)(6.10RC2) RX580 Passthrough Problems
Firstly: Happy New Year unRAID community
I would HUGELY appreciate any help that could be offered here:
I have been reading all the AMD passthrough threads that I could find but I have gotten incredibly confused by conflicting information and information that is possibly no longer valid as per versions 6.9+.
I am swapping the GPU on a Win10 VM from a Nvidia 1050Ti to an AMD RX580 (Gigabyte Aorus RX580 8GB).
I am having a lot of difficulty in getting the RX580 reliably passed through:
I can get it to boot in the VM with a 800x600 resolution and green/blue artifacts on the screen and I am sometimes get the AMD drivers (latest from AMD website) to correctly install but it inevitably crashes and then reboots to show an "Error Code 43" in the device manager for the card.
I have tried completely removing all driver components with DDU in safe mode between attempts but still struggling greatly.
I recently had it working but then after a reboot of the server it reverted to Code 43 again!
Artifacts disappear in safemode so I am fairly confident they are related to drivers/passthrough.
Card is known working as was removed from eGPU enclosure.
My Setup:
M/B: Gigabyte Technology Co., Ltd. C246-WU4-CF Version x.x - s/n: Default string
BIOS: American Megatrends Inc. Version F6g. Dated: 09/16/2020
CPU: Intel® Core™ i9-9900 CPU @ 3.10GHz
HVM: Enabled
IOMMU: Enabled
Cache: 512 KiB, 2 MB, 16 MB
Memory: 64 GiB DDR4 (max. installable capacity 64 GiB)
Network: bond0: fault-tolerance (active-backup), mtu 1500
 eth0: 1000 Mbps, full duplex, mtu 1500
 eth1: 1000 Mbps, full duplex, mtu 1500
Kernel: Linux 5.14.15-Unraid x86_64
I have CSM disabled in BIOS as per some posts I read here.
I have the AMD Vendor Reset Plugin from @ich777 installed:
My System VM Manager Settings are as follows:
I have the following VFIO bindings:
VM Log:
-boot strict=on \
-device pcie-root-port,port=0x8,chassis=1,id=pci.1,bus=pcie.0,multifunction=on,addr=0x1 \
-device pcie-root-port,port=0x9,chassis=2,id=pci.2,bus=pcie.0,addr=0x1.0x1 \
-device pcie-root-port,port=0xa,chassis=3,id=pci.3,bus=pcie.0,addr=0x1.0x2 \
-device pcie-root-port,port=0xb,chassis=4,id=pci.4,bus=pcie.0,addr=0x1.0x3 \
-device pcie-root-port,port=0xc,chassis=5,id=pci.5,bus=pcie.0,addr=0x1.0x4 \
-device pcie-root-port,port=0xd,chassis=6,id=pci.6,bus=pcie.0,addr=0x1.0x5 \
-device pcie-root-port,port=0xe,chassis=7,id=pci.7,bus=pcie.0,addr=0x1.0x6 \
-device pcie-root-port,port=0xf,chassis=8,id=pci.8,bus=pcie.0,addr=0x1.0x7 \
-device pcie-pci-bridge,id=pci.9,bus=pci.1,addr=0x0 \
-device ich9-usb-ehci1,id=usb,bus=pcie.0,addr=0x7.0x7 \
-device ich9-usb-uhci1,masterbus=usb.0,firstport=0,bus=pcie.0,multifunction=on,addr=0x7 \
-device ich9-usb-uhci2,masterbus=usb.0,firstport=2,bus=pcie.0,addr=0x7.0x1 \
-device ich9-usb-uhci3,masterbus=usb.0,firstport=4,bus=pcie.0,addr=0x7.0x2 \
-device virtio-serial-pci,id=virtio-serial0,bus=pci.2,addr=0x0 \
-blockdev '{"driver":"file","filename":"/mnt/disks/CT2000MX500SSD1_2111E589AB92/domains/Windows 10 (BI)/vdisk_new.img","node-name":"libvirt-2-storage","cache":{"direct":false,"no-flush":false},"auto-read-only":true,"discard":"unmap"}' \
-blockdev '{"node-name":"libvirt-2-format","read-only":false,"cache":{"direct":false,"no-flush":false},"driver":"qcow2","file":"libvirt-2-storage","backing":null}' \
-device virtio-blk-pci,bus=pci.4,addr=0x0,drive=libvirt-2-format,id=virtio-disk2,bootindex=1,write-cache=on \
-blockdev '{"driver":"host_device","filename":"/dev/disk/by-id/ata-WDC_WD20PURZ-85AKKY0_WD-WX42D609RS31","node-name":"libvirt-1-storage","cache":{"direct":false,"no-flush":false},"auto-read-only":true,"discard":"unmap"}' \
-blockdev '{"node-name":"libvirt-1-format","read-only":false,"cache":{"direct":false,"no-flush":false},"driver":"raw","file":"libvirt-1-storage"}' \
-device virtio-blk-pci,bus=pci.5,addr=0x0,drive=libvirt-1-format,id=virtio-disk3,write-cache=on \
-netdev tap,fd=39,id=hostnet0 \
-device virtio-net,netdev=hostnet0,id=net0,mac=30:11:d2:80:23:6a,bus=pci.3,addr=0x0 \
-chardev pty,id=charserial0 \
-device isa-serial,chardev=charserial0,id=serial0 \
-chardev socket,id=charchannel0,fd=40,server=on,wait=off \
-device virtserialport,bus=virtio-serial0.0,nr=1,chardev=charchannel0,id=channel0,name=org.qemu.guest_agent.0 \
-device usb-tablet,id=input0,bus=usb.0,port=3 \
-audiodev id=audio1,driver=none \
-device vfio-pci,host=0000:01:00.0,id=hostdev0,bus=pci.6,multifunction=on,addr=0x0,romfile=/mnt/user/Files/VMs/vbios/RX580.Fast.rom \
-device vfio-pci,host=0000:01:00.1,id=hostdev1,bus=pci.6,addr=0x0.0x1 \
-device usb-host,hostdevice=/dev/bus/usb/001/006,id=hostdev2,bus=usb.0,port=1 \
-device usb-host,hostdevice=/dev/bus/usb/001/003,id=hostdev3,bus=usb.0,port=2 \
-sandbox on,obsolete=deny,elevateprivileges=deny,spawn=deny,resourcecontrol=deny \
-msg timestamp=on
char device redirected to /dev/pts/2 (label charserial0)
2022-01-01T23:52:10.162457Z qemu-system-x86_64: vfio: Cannot reset device 0000:01:00.1, no available reset mechanism.
2022-01-01T23:52:10.167466Z qemu-system-x86_64: vfio: Cannot reset device 0000:01:00.1, no available reset mechanism.
2022-01-01T23:59:38.988500Z qemu-system-x86_64: vfio: Cannot reset device 0000:01:00.1, no available reset mechanism.
2022-01-01T23:59:38.994580Z qemu-system-x86_64: vfio: Cannot reset device 0000:01:00.1, no available reset mechanism.
VM XML:
<domain type='kvm'>
  <name>Windows 10 BI XML_Edits</name>
  <uuid>33eb8092-98b7-7fb8-c0c4-219f958f4b13</uuid>
  <metadata>
  </metadata>
  <memory unit='KiB'>16777216</memory>
  <currentMemory unit='KiB'>16777216</currentMemory>
  <memoryBacking>
    <nosharepages/>
  </memoryBacking>
  <vcpu placement='static'>6</vcpu>
  <cputune>
    <vcpupin vcpu='0' cpuset='5'/>
    <vcpupin vcpu='1' cpuset='13'/>
    <vcpupin vcpu='2' cpuset='6'/>
    <vcpupin vcpu='3' cpuset='14'/>
    <vcpupin vcpu='4' cpuset='7'/>
    <vcpupin vcpu='5' cpuset='15'/>
  </cputune>
  <os>
    <type arch='x86_64' machine='pc-q35-6.1'>hvm</type>
    <nvram>/etc/libvirt/qemu/nvram/33eb8092-98b7-7fb8-c0c4-219f958f4b13_VARS-pure-efi.fd</nvram>
  </os>
  <features>
    <acpi/>
    <apic/>
    <hyperv>
      <relaxed state='on'/>
      <vapic state='on'/>
    </hyperv>
  </features>
    <topology sockets='1' dies='1' cores='3' threads='2'/>
    <cache mode='passthrough'/>
  </cpu>
  <clock offset='localtime'>
  </clock>
  <on_crash>restart</on_crash>
  <devices>
      <driver name='qemu' type='qcow2' cache='writeback'/>
      <source file='/mnt/disks/CT2000MX500SSD1_2111E589AB92/domains/Windows 10 (BI)/vdisk_new.img'/>
      <boot order='1'/>
      <address type='pci' domain='0x0000' bus='0x04' slot='0x00' function='0x0'/>
    </disk>
    <disk type='block' device='disk'>
      <source dev='/dev/disk/by-id/ata-WDC_WD20PURZ-85AKKY0_WD-WX42D609RS31'/>
      <target dev='hdd' bus='virtio'/>
      <address type='pci' domain='0x0000' bus='0x05' slot='0x00' function='0x0'/>
    </disk>
    </controller>
      <master startport='0'/>
    </controller>
      <master startport='2'/>
    </controller>
      <master startport='4'/>
    </controller>
    <controller type='pci' index='0' model='pcie-root'/>
    <controller type='pci' index='1' model='pcie-root-port'>
      <model name='pcie-root-port'/>
      <target chassis='1' port='0x8'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x01' function='0x0' multifunction='on'/>
    </controller>
    <controller type='pci' index='2' model='pcie-root-port'>
      <target chassis='2' port='0x9'/>
    </controller>
    <controller type='pci' index='3' model='pcie-root-port'>
      <target chassis='3' port='0xa'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x01' function='0x2'/>
    </controller>
    <controller type='pci' index='4' model='pcie-root-port'>
      <target chassis='4' port='0xb'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x01' function='0x3'/>
    </controller>
    <controller type='pci' index='5' model='pcie-root-port'>
      <target chassis='5' port='0xc'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x01' function='0x4'/>
    </controller>
    <controller type='pci' index='6' model='pcie-root-port'>
      <target chassis='6' port='0xd'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x01' function='0x5'/>
    </controller>
    <controller type='pci' index='7' model='pcie-root-port'>
      <target chassis='7' port='0xe'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x01' function='0x6'/>
    </controller>
    <controller type='pci' index='8' model='pcie-root-port'>
      <target chassis='8' port='0xf'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x01' function='0x7'/>
    </controller>
    <controller type='pci' index='9' model='pcie-to-pci-bridge'>
      <model name='pcie-pci-bridge'/>
      <address type='pci' domain='0x0000' bus='0x01' slot='0x00' function='0x0'/>
    </controller>
      <address type='pci' domain='0x0000' bus='0x02' slot='0x00' function='0x0'/>
    </controller>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x1f' function='0x2'/>
    </controller>
    <interface type='bridge'>
      <mac address='30:11:d2:80:23:6a'/>
      <source bridge='br0'/>
      <model type='virtio-net'/>
      <address type='pci' domain='0x0000' bus='0x03' slot='0x00' function='0x0'/>
    </interface>
    <serial type='pty'>
        <model name='isa-serial'/>
      </target>
    </serial>
    <console type='pty'>
    </console>
    <channel type='unix'>
    </channel>
      <address type='usb' bus='0' port='3'/>
    </input>
    <audio id='1' type='none'/>
      <driver name='vfio'/>
      <source>
        <address domain='0x0000' bus='0x01' slot='0x00' function='0x0'/>
      </source>
      <rom file='/mnt/user/Files/VMs/vbios/RX580.Fast.rom'/>
      <address type='pci' domain='0x0000' bus='0x06' slot='0x00' function='0x0' multifunction='on'/>
    </hostdev>
      <source>
        <address domain='0x0000' bus='0x01' slot='0x00' function='0x1'/>
      </source>
      <address type='pci' domain='0x0000' bus='0x06' slot='0x00' function='0x1'/>
    </hostdev>
    <hostdev mode='subsystem' type='usb' managed='no'>
      <source>
        <vendor id='0x413c'/>
        <product id='0x2003'/>
      </source>
    </hostdev>
      <source>
        <product id='0x3012'/>
      </source>
      <address type='usb' bus='0' port='2'/>
    </hostdev>
    <memballoon model='none'/>
  </devices>
</domain>
NOTE:
I have tried it both with and without vbios files as I have read conflicting reports of their importance for AMD cards.
I have ran a vbios file that I dumped myself via @SpaceInvaderOne script and have ran ones downloaded from techpowerup.com
There has been no difference in success either way.
I have nothing special in my syslinux.cfg:
kernel /bzimage
append isolcpus=5-7,13-15 pcie_acs_override=downstream initrd=/bzroot
Diagnostics attached also:
Thanks so much for any advice!
tower-diagnostics-20220102-0013.zip
Edited by Capt.Insano
Update title
Can you please verify that the card is working in another computer, also try to install the drivers for the card and put a 3D load on it for about 5 to 10 minutes and see if you got no artifacts.
Usually this is caused when the card is defective but in your case this can also be an issue with the Passthrough itself but I would at least verify that it works in another computer (without the enclosure).
Seems you may be right! 😭
Booted the same unraid hardware with a Windows 10 drive and also got Code 43 errors after driver installation.
What a balls! GPUs are just so expensive at the moment.
Thanks for your advice
  • Capt.Insano changed the title to (SOLVED - Faulty Card)(6.10RC2) RX580 Passthrough Problems
