Hypner Posted January 22, 2022 Share Posted January 22, 2022 I haven't had a struggle like this in some time with Unraid but while using my server plex became less and less stable last night. To the point where I decided to simply restart my server as I figured it would be a good time since there was an update for the NVidia driver. The reboot went fine and Unraid started back up. But when I went to start the array the array simply stalled would not start up and I decided to restart the server again. I tried starting the array in maintenance mode which worked. I moved on to stopping the array and starting it like normal. I am running a mount script for gdrive and started that to initiate my containers to start. This is what I encountered and result of that mount script running. 2.01.2022 07:55:17 INFO: Creating local folders. 22.01.2022 07:55:17 INFO: Creating MergerFS folders. 22.01.2022 07:55:17 INFO: *** Starting mount of remote gdrive_vfs 22.01.2022 07:55:17 INFO: Checking if this script is already running. 22.01.2022 07:55:17 INFO: Script not running - proceeding. 22.01.2022 07:55:17 INFO: *** Checking if online 22.01.2022 07:55:18 PASSED: *** Internet online 22.01.2022 07:55:18 INFO: Success gdrive_vfs remote is already mounted. 22.01.2022 07:55:18 INFO: Mergerfs not installed - installing now. 2022/01/22 07:56:15 INFO : vfs cache: cleaned: objects 13568 (was 13568) in use 0, to upload 0, uploading 0, total size 399.140Gi (was 399.140Gi) docker: Error response from daemon: open /var/lib/docker/containers/dac1a5ee9b9a8cb7da145119a4b71ad2c543672c0a43a63cb3d54bf09726ed91/.tmp-config.v2.json565736439: read-only file system. See 'docker run --help'. mv: cannot stat '/mnt/user/appdata/other/rclone/mergerfs/mergerfs': No such file or directory 22.01.2022 07:56:48 INFO: *sleeping for 5 seconds docker: Error response from daemon: read-only file system: unknown. time="2022-01-22T07:56:48-08:00" level=error msg="Error waiting for container: container a2d258183f0a4a769bb9bbf41dc2e1ffb8069a5fbcc00181d3ec9fd3215e9fce: driver \"btrfs\" failed to remove root filesystem: Recursively walking subvolumes for /var/lib/docker/btrfs/subvolumes failed: error walking subvolumes: readdirent: input/output error" 22.01.2022 07:56:53 ERROR: Mergerfs not installed successfully. Please check for errors. Exiting. rm: cannot remove '/mnt/user/appdata/other/rclone/remotes/gdrive_vfs/mount_running': Read-only file system Script Finished Jan 22, 2022 07:56.53 Additionally the system log Jan 22 07:54:58 Keep emhttpd: cmd: /usr/local/emhttp/plugins/user.scripts/showLog.php Mount script Jan 22 07:55:07 Keep emhttpd: cmd: /usr/local/emhttp/plugins/user.scripts/backgroundScript.sh /tmp/user.scripts/tmpScripts/Cleanup Script/script Jan 22 07:55:10 Keep emhttpd: cmd: /usr/local/emhttp/plugins/user.scripts/showLog.php Cleanup Script Jan 22 07:55:17 Keep emhttpd: cmd: /usr/local/emhttp/plugins/user.scripts/backgroundScript.sh /tmp/user.scripts/tmpScripts/Mount script/script Jan 22 07:55:19 Keep emhttpd: cmd: /usr/local/emhttp/plugins/user.scripts/showLog.php Mount script Jan 22 07:56:08 Keep nginx: 2022/01/22 07:56:08 [error] 9580#9580: *68623 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 192.168.1.59, server: , request: "POST /plugins/community.applications/scripts/notices.php HTTP/1.1", upstream: "fastcgi://unix:/var/run/php5-fpm.sock", host: "192.168.1.174", referrer: "http://192.168.1.174/Settings/Userscripts" Jan 22 07:56:25 Keep nginx: 2022/01/22 07:56:25 [error] 9580#9580: *68651 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 192.168.1.59, server: , request: "POST /plugins/community.applications/scripts/notices.php HTTP/1.1", upstream: "fastcgi://unix:/var/run/php5-fpm.sock", host: "192.168.1.174", referrer: "http://192.168.1.174/Tools/Syslog" Jan 22 07:56:47 Keep kernel: sd 1:0:12:0: [sdg] tag#18 UNKNOWN(0x2003) Result: hostbyte=0x00 driverbyte=0x08 cmd_age=0s Jan 22 07:56:47 Keep kernel: sd 1:0:12:0: [sdg] tag#18 Sense Key : 0x4 [current] Jan 22 07:56:47 Keep kernel: sd 1:0:12:0: [sdg] tag#18 ASC=0x44 ASCQ=0x0 Jan 22 07:56:47 Keep kernel: sd 1:0:12:0: [sdg] tag#18 CDB: opcode=0x2a 2a 00 00 00 00 c0 00 00 08 00 Jan 22 07:56:47 Keep kernel: blk_update_request: critical target error, dev sdg, sector 192 op 0x1:(WRITE) flags 0x3800 phys_seg 1 prio class 0 Jan 22 07:56:47 Keep kernel: blk_update_request: critical target error, dev sdg, sector 192 op 0x1:(WRITE) flags 0x3800 phys_seg 1 prio class 0 Jan 22 07:56:47 Keep kernel: BTRFS warning (device sdg1): lost page write due to IO error on /dev/sdg1 (-121) Jan 22 07:56:47 Keep kernel: BTRFS error (device sdg1): bdev /dev/sdg1 errs: wr 1, rd 0, flush 0, corrupt 0, gen 0 Jan 22 07:56:47 Keep kernel: BTRFS error (device sdg1): error writing primary super block to device 1 Jan 22 07:56:47 Keep kernel: BTRFS: error (device sdg1) in write_all_supers:3915: errno=-5 IO failure (1 errors while writing supers) Jan 22 07:56:47 Keep kernel: BTRFS info (device sdg1): forced readonly Jan 22 07:56:47 Keep kernel: BTRFS: error (device sdg1) in btrfs_sync_log:3221: errno=-5 IO failure Jan 22 07:56:47 Keep kernel: blk_update_request: I/O error, dev loop2, sector 128 op 0x1:(WRITE) flags 0x3800 phys_seg 1 prio class 0 Jan 22 07:56:47 Keep kernel: BTRFS warning (device loop2): lost page write due to IO error on /dev/loop2 (-5) Jan 22 07:56:47 Keep kernel: BTRFS error (device loop2): bdev /dev/loop2 errs: wr 1, rd 0, flush 0, corrupt 0, gen 0 Jan 22 07:56:47 Keep kernel: BTRFS error (device loop2): error writing primary super block to device 1 Jan 22 07:56:47 Keep kernel: BTRFS: error (device loop2) in write_all_supers:3915: errno=-5 IO failure (1 errors while writing supers) Jan 22 07:56:47 Keep kernel: BTRFS info (device loop2): forced readonly Jan 22 07:56:47 Keep kernel: BTRFS: error (device loop2) in btrfs_sync_log:3221: errno=-5 IO failure Jan 22 07:56:47 Keep kernel: BTRFS warning (device loop2): Skipping commit of aborted transaction. Jan 22 07:56:47 Keep kernel: BTRFS: error (device loop2) in cleanup_transaction:1942: errno=-5 IO failure Jan 22 07:56:47 Keep kernel: sd 1:0:12:0: [sdg] tag#19 UNKNOWN(0x2003) Result: hostbyte=0x00 driverbyte=0x08 cmd_age=0s Jan 22 07:56:47 Keep kernel: sd 1:0:12:0: [sdg] tag#19 Sense Key : 0x4 [current] Jan 22 07:56:47 Keep kernel: sd 1:0:12:0: [sdg] tag#19 ASC=0x44 ASCQ=0x0 Jan 22 07:56:47 Keep kernel: sd 1:0:12:0: [sdg] tag#19 CDB: opcode=0x28 28 00 00 f5 4a f0 00 00 20 00 Jan 22 07:56:47 Keep kernel: blk_update_request: critical target error, dev sdg, sector 16075504 op 0x0:(READ) flags 0x0 phys_seg 4 prio class 0 Jan 22 07:56:47 Keep kernel: BTRFS error (device sdg1): bdev /dev/sdg1 errs: wr 1, rd 1, flush 0, corrupt 0, gen 0 Jan 22 07:56:47 Keep kernel: BTRFS error (device sdg1): bdev /dev/sdg1 errs: wr 1, rd 2, flush 0, corrupt 0, gen 0 Jan 22 07:56:47 Keep kernel: BTRFS error (device sdg1): bdev /dev/sdg1 errs: wr 1, rd 3, flush 0, corrupt 0, gen 0 Jan 22 07:56:47 Keep kernel: BTRFS error (device sdg1): bdev /dev/sdg1 errs: wr 1, rd 4, flush 0, corrupt 0, gen 0 Jan 22 07:56:47 Keep kernel: BTRFS warning (device sdg1): direct IO failed ino 112218869 rw 0,0 sector 0xf54af8 len 0 err no 10 Jan 22 07:56:47 Keep kernel: BTRFS warning (device sdg1): direct IO failed ino 112218869 rw 0,0 sector 0xf54b00 len 0 err no 10 Jan 22 07:56:47 Keep kernel: BTRFS warning (device sdg1): direct IO failed ino 112218869 rw 0,0 sector 0xf54b08 len 0 err no 10 Jan 22 07:56:47 Keep kernel: BTRFS warning (device sdg1): direct IO failed ino 112218869 rw 0,0 sector 0xf54b10 len 0 err no 10 Jan 22 07:56:47 Keep kernel: blk_update_request: I/O error, dev loop2, sector 528608 op 0x0:(READ) flags 0x1000 phys_seg 3 prio class 0 Jan 22 07:56:47 Keep kernel: BTRFS error (device loop2): bdev /dev/loop2 errs: wr 1, rd 1, flush 0, corrupt 0, gen 0 Jan 22 07:56:47 Keep kernel: sd 1:0:12:0: [sdg] tag#16 UNKNOWN(0x2003) Result: hostbyte=0x00 driverbyte=0x08 cmd_age=0s Jan 22 07:56:47 Keep kernel: sd 1:0:12:0: [sdg] tag#16 Sense Key : 0x4 [current] Jan 22 07:56:47 Keep kernel: sd 1:0:12:0: [sdg] tag#16 ASC=0x44 ASCQ=0x0 Jan 22 07:56:47 Keep kernel: sd 1:0:12:0: [sdg] tag#16 CDB: opcode=0x28 28 00 00 f5 4b 30 00 00 20 00 Jan 22 07:56:47 Keep kernel: blk_update_request: critical target error, dev sdg, sector 16075568 op 0x0:(READ) flags 0x0 phys_seg 4 prio class 0 Jan 22 07:56:47 Keep kernel: BTRFS error (device sdg1): bdev /dev/sdg1 errs: wr 1, rd 5, flush 0, corrupt 0, gen 0 Jan 22 07:56:47 Keep kernel: BTRFS error (device sdg1): bdev /dev/sdg1 errs: wr 1, rd 6, flush 0, corrupt 0, gen 0 Jan 22 07:56:47 Keep kernel: BTRFS error (device sdg1): bdev /dev/sdg1 errs: wr 1, rd 7, flush 0, corrupt 0, gen 0 Jan 22 07:56:47 Keep kernel: BTRFS warning (device sdg1): direct IO failed ino 112218869 rw 0,0 sector 0xf54b38 len 0 err no 10 Jan 22 07:56:47 Keep kernel: BTRFS warning (device sdg1): direct IO failed ino 112218869 rw 0,0 sector 0xf54b40 len 0 err no 10 Jan 22 07:56:47 Keep kernel: BTRFS warning (device sdg1): direct IO failed ino 112218869 rw 0,0 sector 0xf54b48 len 0 err no 10 Jan 22 07:56:47 Keep kernel: BTRFS warning (device sdg1): direct IO failed ino 112218869 rw 0,0 sector 0xf54b50 len 0 err no 10 Jan 22 07:56:47 Keep kernel: blk_update_request: I/O error, dev loop2, sector 528672 op 0x0:(READ) flags 0x1000 phys_seg 3 prio class 0 Jan 22 07:56:47 Keep kernel: sd 1:0:12:0: [sdg] tag#17 UNKNOWN(0x2003) Result: hostbyte=0x00 driverbyte=0x08 cmd_age=0s Jan 22 07:56:47 Keep kernel: sd 1:0:12:0: [sdg] tag#17 Sense Key : 0x4 [current] Jan 22 07:56:47 Keep kernel: sd 1:0:12:0: [sdg] tag#17 ASC=0x44 ASCQ=0x0 Jan 22 07:56:47 Keep kernel: sd 1:0:12:0: [sdg] tag#17 CDB: opcode=0x28 28 00 00 f5 4b 10 00 00 20 00 Jan 22 07:56:47 Keep kernel: blk_update_request: critical target error, dev sdg, sector 16075536 op 0x0:(READ) flags 0x0 phys_seg 4 prio class 0 Jan 22 07:56:47 Keep kernel: BTRFS warning (device sdg1): direct IO failed ino 112218869 rw 0,0 sector 0xf54b18 len 0 err no 10 Jan 22 07:56:47 Keep kernel: BTRFS warning (device sdg1): direct IO failed ino 112218869 rw 0,0 sector 0xf54b20 len 0 err no 10 Jan 22 07:56:47 Keep kernel: BTRFS warning (device sdg1): direct IO failed ino 112218869 rw 0,0 sector 0xf54b30 len 0 err no 10 Jan 22 07:56:47 Keep kernel: BTRFS warning (device sdg1): direct IO failed ino 112218869 rw 0,0 sector 0xf54b28 len 0 err no 10 Jan 22 07:56:47 Keep kernel: blk_update_request: I/O error, dev loop2, sector 528640 op 0x0:(READ) flags 0x1000 phys_seg 3 prio class 0 Jan 22 07:56:47 Keep kernel: sd 1:0:12:0: [sdg] tag#18 UNKNOWN(0x2003) Result: hostbyte=0x00 driverbyte=0x08 cmd_age=0s Jan 22 07:56:47 Keep kernel: sd 1:0:12:0: [sdg] tag#18 Sense Key : 0x4 [current] Jan 22 07:56:47 Keep kernel: sd 1:0:12:0: [sdg] tag#18 ASC=0x44 ASCQ=0x0 Jan 22 07:56:47 Keep kernel: sd 1:0:12:0: [sdg] tag#18 CDB: opcode=0x28 28 00 00 f5 4b 70 00 00 20 00 Jan 22 07:56:47 Keep kernel: blk_update_request: critical target error, dev sdg, sector 16075632 op 0x0:(READ) flags 0x0 phys_seg 4 prio class 0 Jan 22 07:56:47 Keep kernel: BTRFS warning (device sdg1): direct IO failed ino 112218869 rw 0,0 sector 0xf54b78 len 0 err no 10 Jan 22 07:56:47 Keep kernel: BTRFS warning (device sdg1): direct IO failed ino 112218869 rw 0,0 sector 0xf54b80 len 0 err no 10 Jan 22 07:56:47 Keep kernel: BTRFS warning (device sdg1): direct IO failed ino 112218869 rw 0,0 sector 0xf54b90 len 0 err no 10 Jan 22 07:56:47 Keep kernel: BTRFS warning (device sdg1): direct IO failed ino 112218869 rw 0,0 sector 0xf54b88 len 0 err no 10 Jan 22 07:56:47 Keep kernel: sd 1:0:12:0: [sdg] tag#16 UNKNOWN(0x2003) Result: hostbyte=0x00 driverbyte=0x08 cmd_age=0s Jan 22 07:56:47 Keep kernel: sd 1:0:12:0: [sdg] tag#16 Sense Key : 0x4 [current] Jan 22 07:56:47 Keep kernel: sd 1:0:12:0: [sdg] tag#16 ASC=0x44 ASCQ=0x0 Jan 22 07:56:47 Keep kernel: sd 1:0:12:0: [sdg] tag#16 CDB: opcode=0x28 28 00 03 80 b9 a0 00 00 20 00 Jan 22 07:56:47 Keep kernel: BTRFS warning (device sdg1): direct IO failed ino 112218869 rw 0,0 sector 0x380b9a8 len 0 err no 10 Jan 22 07:56:47 Keep kernel: BTRFS warning (device sdg1): direct IO failed ino 112218869 rw 0,0 sector 0x380b9b0 len 0 err no 10 Jan 22 07:56:47 Keep kernel: BTRFS warning (device sdg1): direct IO failed ino 112218869 rw 0,0 sector 0x380b9c0 len 0 err no 10 Jan 22 07:56:47 Keep kernel: BTRFS warning (device sdg1): direct IO failed ino 112218869 rw 0,0 sector 0x380b9b8 len 0 err no 10 Jan 22 07:56:47 Keep kernel: sd 1:0:12:0: [sdg] tag#17 UNKNOWN(0x2003) Result: hostbyte=0x00 driverbyte=0x08 cmd_age=0s Jan 22 07:56:47 Keep kernel: sd 1:0:12:0: [sdg] tag#17 Sense Key : 0x4 [current] Jan 22 07:56:47 Keep kernel: sd 1:0:12:0: [sdg] tag#17 ASC=0x44 ASCQ=0x0 Jan 22 07:56:47 Keep kernel: sd 1:0:12:0: [sdg] tag#17 CDB: opcode=0x28 28 00 00 f5 4b 70 00 00 20 00 Jan 22 07:56:47 Keep kernel: BTRFS warning (device sdg1): direct IO failed ino 112218869 rw 0,0 sector 0xf54b78 len 0 err no 10 Jan 22 07:56:47 Keep kernel: BTRFS warning (device sdg1): direct IO failed ino 112218869 rw 0,0 sector 0xf54b80 len 0 err no 10 Jan 22 07:56:47 Keep kernel: BTRFS warning (device sdg1): direct IO failed ino 112218869 rw 0,0 sector 0xf54b88 len 0 err no 10 Jan 22 07:56:47 Keep kernel: BTRFS warning (device sdg1): direct IO failed ino 112218869 rw 0,0 sector 0xf54b90 len 0 err no 10 Jan 22 07:56:47 Keep kernel: sd 1:0:12:0: [sdg] tag#18 UNKNOWN(0x2003) Result: hostbyte=0x00 driverbyte=0x08 cmd_age=0s Jan 22 07:56:47 Keep kernel: sd 1:0:12:0: [sdg] tag#18 Sense Key : 0x4 [current] Jan 22 07:56:47 Keep kernel: sd 1:0:12:0: [sdg] tag#18 ASC=0x44 ASCQ=0x0 Jan 22 07:56:47 Keep kernel: sd 1:0:12:0: [sdg] tag#18 CDB: opcode=0x28 28 00 00 f5 4b 70 00 00 20 00 Jan 22 07:56:47 Keep kernel: BTRFS warning (device sdg1): direct IO failed ino 112218869 rw 0,0 sector 0xf54b78 len 0 err no 10 Jan 22 07:56:47 Keep kernel: BTRFS warning (device sdg1): direct IO failed ino 112218869 rw 0,0 sector 0xf54b88 len 0 err no 10 Jan 22 07:56:47 Keep kernel: BTRFS warning (device sdg1): direct IO failed ino 112218869 rw 0,0 sector 0xf54b80 len 0 err no 10 Jan 22 07:56:47 Keep kernel: BTRFS warning (device sdg1): direct IO failed ino 112218869 rw 0,0 sector 0xf54b90 len 0 err no 10 Jan 22 07:56:47 Keep kernel: sd 1:0:12:0: [sdg] tag#19 UNKNOWN(0x2003) Result: hostbyte=0x00 driverbyte=0x08 cmd_age=0s Jan 22 07:56:47 Keep kernel: sd 1:0:12:0: [sdg] tag#19 Sense Key : 0x4 [current] Jan 22 07:56:47 Keep kernel: sd 1:0:12:0: [sdg] tag#19 ASC=0x44 ASCQ=0x0 Jan 22 07:56:47 Keep kernel: sd 1:0:12:0: [sdg] tag#19 CDB: opcode=0x28 28 00 03 80 b9 a0 00 00 20 00 Jan 22 07:56:47 Keep kernel: BTRFS warning (device sdg1): direct IO failed ino 112218869 rw 0,0 sector 0x380b9a8 len 0 err no 10 Jan 22 07:56:47 Keep kernel: BTRFS warning (device sdg1): direct IO failed ino 112218869 rw 0,0 sector 0x380b9b0 len 0 err no 10 Jan 22 07:56:47 Keep kernel: BTRFS warning (device sdg1): direct IO failed ino 112218869 rw 0,0 sector 0x380b9b8 len 0 err no 10 Jan 22 07:56:47 Keep kernel: BTRFS warning (device sdg1): direct IO failed ino 112218869 rw 0,0 sector 0x380b9c0 len 0 err no 10 Jan 22 07:56:47 Keep kernel: sd 1:0:12:0: [sdg] tag#16 UNKNOWN(0x2003) Result: hostbyte=0x00 driverbyte=0x08 cmd_age=0s Jan 22 07:56:47 Keep kernel: sd 1:0:12:0: [sdg] tag#16 Sense Key : 0x4 [current] Jan 22 07:56:47 Keep kernel: sd 1:0:12:0: [sdg] tag#16 ASC=0x44 ASCQ=0x0 Jan 22 07:56:47 Keep kernel: sd 1:0:12:0: [sdg] tag#16 CDB: opcode=0x28 28 00 00 f5 4b 70 00 00 20 00 Jan 22 07:56:47 Keep kernel: BTRFS warning (device sdg1): direct IO failed ino 112218869 rw 0,0 sector 0xf54b78 len 0 err no 10 Jan 22 07:56:47 Keep kernel: BTRFS warning (device sdg1): direct IO failed ino 112218869 rw 0,0 sector 0xf54b80 len 0 err no 10 Jan 22 07:56:47 Keep kernel: BTRFS warning (device sdg1): direct IO failed ino 112218869 rw 0,0 sector 0xf54b88 len 0 err no 10 Jan 22 07:56:47 Keep kernel: BTRFS warning (device sdg1): direct IO failed ino 112218869 rw 0,0 sector 0xf54b90 len 0 err no 10 Jan 22 07:56:48 Keep kernel: BTRFS warning (device sdg1): direct IO failed ino 112218869 rw 0,0 sector 0xf54af8 len 0 err no 10 Jan 22 07:56:48 Keep kernel: BTRFS warning (device sdg1): direct IO failed ino 112218869 rw 0,0 sector 0xf54b00 len 0 err no 10 Jan 22 07:56:48 Keep kernel: BTRFS warning (device sdg1): direct IO failed ino 112218869 rw 0,0 sector 0xf54b08 len 0 err no 10 Jan 22 07:56:48 Keep kernel: BTRFS warning (device sdg1): direct IO failed ino 112218869 rw 0,0 sector 0xf54b10 len 0 err no 10 Jan 22 07:56:48 Keep kernel: BTRFS warning (device sdg1): direct IO failed ino 112218869 rw 0,0 sector 0xf54b38 len 0 err no 10 Jan 22 07:56:48 Keep kernel: BTRFS warning (device sdg1): direct IO failed ino 112218869 rw 0,0 sector 0xf54b40 len 0 err no 10 Jan 22 07:56:48 Keep kernel: BTRFS warning (device sdg1): direct IO failed ino 112218869 rw 0,0 sector 0xf54b48 len 0 err no 10 Jan 22 07:56:48 Keep kernel: BTRFS warning (device sdg1): direct IO failed ino 112218869 rw 0,0 sector 0xf54b50 len 0 err no 10 Jan 22 07:56:48 Keep kernel: BTRFS warning (device sdg1): direct IO failed ino 112218869 rw 0,0 sector 0xf54b18 len 0 err no 10 Jan 22 07:56:48 Keep kernel: BTRFS warning (device sdg1): direct IO failed ino 112218869 rw 0,0 sector 0xf54b20 len 0 err no 10 Jan 22 07:56:48 Keep kernel: BTRFS warning (device sdg1): direct IO failed ino 112218869 rw 0,0 sector 0xf54b28 len 0 err no 10 Jan 22 07:56:48 Keep kernel: BTRFS warning (device sdg1): direct IO failed ino 112218869 rw 0,0 sector 0xf54b30 len 0 err no 10 Jan 22 07:56:48 Keep kernel: BTRFS warning (device sdg1): direct IO failed ino 112218869 rw 0,0 sector 0xf54b78 len 0 err no 10 Jan 22 07:56:48 Keep kernel: BTRFS warning (device sdg1): direct IO failed ino 112218869 rw 0,0 sector 0xf54b80 len 0 err no 10 Jan 22 07:56:48 Keep kernel: BTRFS warning (device sdg1): direct IO failed ino 112218869 rw 0,0 sector 0xf54b88 len 0 err no 10 Jan 22 07:56:48 Keep kernel: BTRFS warning (device sdg1): direct IO failed ino 112218869 rw 0,0 sector 0xf54b90 len 0 err no 10 Jan 22 07:56:48 Keep kernel: BTRFS warning (device sdg1): direct IO failed ino 112218869 rw 0,0 sector 0x380b9a8 len 0 err no 10 Jan 22 07:56:48 Keep kernel: BTRFS warning (device sdg1): direct IO failed ino 112218869 rw 0,0 sector 0x380b9b0 len 0 err no 10 Jan 22 07:56:48 Keep kernel: BTRFS warning (device sdg1): direct IO failed ino 112218869 rw 0,0 sector 0x380b9b8 len 0 err no 10 Jan 22 07:56:48 Keep kernel: BTRFS warning (device sdg1): direct IO failed ino 112218869 rw 0,0 sector 0x380b9c0 len 0 err no 10 Jan 22 07:57:13 Keep kernel: print_req_error: 21 callbacks suppressed Jan 22 07:57:13 Keep kernel: blk_update_request: I/O error, dev loop2, sector 11710736 op 0x1:(WRITE) flags 0x100000 phys_seg 1 prio class 0 Jan 22 07:57:13 Keep kernel: btrfs_dev_stat_print_on_error: 62 callbacks suppressed Jan 22 07:57:13 Keep kernel: BTRFS error (device loop2): bdev /dev/loop2 errs: wr 2, rd 14, flush 0, corrupt 0, gen 0 Jan 22 07:57:13 Keep kernel: blk_update_request: I/O error, dev loop2, sector 11711056 op 0x1:(WRITE) flags 0x100000 phys_seg 1 prio class 0 Jan 22 07:57:13 Keep kernel: BTRFS error (device loop2): bdev /dev/loop2 errs: wr 3, rd 14, flush 0, corrupt 0, gen 0 Every error is related to device sdg1 which is my lone cache drive. Looking to get some direction on what to do next. Help would be greatly appreciated. Quote Link to comment
JorgeB Posted January 23, 2022 Share Posted January 23, 2022 This is a hardware issue, diagnostics might give more clues. Quote Link to comment
