settings for specific disks are not saved - please help!!
I have problems with making disk settings persistent. 2 of my nvme disks are heating up to 51 degres. overheating alarm is set by default to 45. I can go to specific disk and change  Warning disk temperature threshold (°C): to 55 but when i edit diferent disk or restart unraid -  changes are not saved. i also posted topic about saving settings about controler type  over month ago but nobody answered. See movie in that post you will see what i mean.
https://forums.unraid.net/bug-reports/stable-releases/692-smart-settings-for-individual-disk-is-not-saved-r1757/
Problems seems to be related.  thesame is happening when you unselect some SMART warnings (199 for example) -  this is also not saved.
Can some one help me?
Edited by MoherPower
What release of Unraid are you running?
Version 6.9.2 2021-04-07
Base distro:
docker: version 20.10.5
fuse3: version 3.10.2
nginx: version 1.19.9
samba: verson 4.12.14 (CVE-2020-27840 CVE-2020-27840)
Linux kernel:
version 5.10.28
include all CONFIG_NF_* modules
oot: realtek r8125: version 9.005.01
So is the question about version is all you can do to help me in both cases?
If I remember correctly that is a known bug in the 6.9.2 release that is fixed in the 6.10.0-rc4 release.
thank you very much.
Is there a walk around for it. right now my raid controler is not reading smart status. i dont know about condition of my disks, i have alot thermal warnings.,becouse of nvme. Also can you tell me if problems with SMART tests on SAS drives also a known problem for 6.9.2? whan i want test SAS disk i have error message right away.
You can manually edit smart-one.cfg on the flahs drive to add the other devices.
