X570M Pro 4 - Power Supply Idle Control
I just replaced the CPU in my X570M Pro4, changing from a 3200g to a 5700g.
I can no longer find the setting in the UEFI called 'Power Supply Idle Control' - anyone know if its been renamed, removed, or fixed?
(Or even needed anymore with newer agesa's?)
I was using it as a workaround/fix for the Ryzen kernel panic bug in unRAID/Linux Kernel.
Thanks!
  • 5 weeks later...
Me neither.
Which BIOS are you running?
