September 24, 20224 yr I received an email this morning with this error- tinc:4 keyword 'size' not properly separated, found 0x3d error: stat of /var/log/tinc.* failed: No such file or directory No idea what it's referring to though. I can tell from the time on the email that it occurred when the daily schedule ran this morning but AFAIK I don't have any user scripts on the daily schedule so presumably it would be one of the system tasks. brunnhilde-diagnostics-20220924-1545.zip
September 27, 20224 yr Same here. I thought it came from the plugin "Nerdpack". But I had already uninstalled this and still have the problem. So I installed and uninstalled Nerdpack again. But made no change. Do you have Nerdpack or did you have installed it before?
September 27, 20224 yr Author This issue started after I removed all the nerd pack pkgs I had installed (screen & ncurses). Re-installing them didn’t correct the issue but after updating to 6.11 last night I am no longer getting the emails.
September 27, 20224 yr Author 38 minutes ago, Squid said: This may fix you up: Where is that setting? I’m not seeing anything for log rotate.
