January 27, 200818 yr I deleted all of the shares in "My Network Places" with the server turned off. When I rebooted, all of the shares are gone. I can still get to the Tower via "View Workgroup Computers" Yes. I think I see the problem. There is a user share named "disk2" which is conflicting with the "disk2" automatically-generated share - this will cause very strange things to happen. There must be some disk which has a top-level directory named "disk2". Probably the easiest way to find it is to temporarily disable User Shares, then go to each disk share, looking for a directory in the share named "disk2" - then rename/delete that directory & re-enable User Shares.
January 27, 200818 yr Author Halleluiah!!! Problem solved. That was exactly the problem. When I moved the data off of the old Disk2, I used the copy commands inside telnet. That created a folder on disk3 called "disk2". I never even thought to delete it. Now in hindsight, it seems so obvious. Thanks for your help.
