Defuse Posted October 31, 2022 Share Posted October 31, 2022 I recently upgraded my server to a ROG STRIX X299-E Gaming and i9-7900X. The NIC I use is an Intel 82599ES 10Gig. I also upgraded the cache disks from a 500GiB setup to a 1 TiB setup. Still SATA based SSD's though. Samsung 870s to be specific. On my previous setup I was able to copy data from my workstation that also uses 10g network at 800-900 MBps without issue. Now after my server hardware changes I am only able to achieve 100 MBps throughput. I am having a hard time identifying what could be causing this. Quote Link to comment
Solution JorgeB Posted October 31, 2022 Solution Share Posted October 31, 2022 Start by checking the LAN link speed and/or running iperf. Quote Link to comment
Defuse Posted October 31, 2022 Author Share Posted October 31, 2022 1 minute ago, JorgeB said: Start by checking the LAN link speed and/or running iperf. Ahh good catch. The link is only running at 1 GB. Now I need to figure out how to fix that.. Quote Link to comment
Defuse Posted October 31, 2022 Author Share Posted October 31, 2022 Turns out it was a bad SFP. Thanks for the help JorgeB 1 Quote Link to comment
