Jump to content
Parity drive warnings: current pending sector is 8 and offline uncorrectable is 1
I received the above two warnings this morning. I have done some searching and seemingly the first step is to try and run an extended SMART test. When I try to run it, it completes very quickly with a message "Completed: read failure". The array seems to running ok without issue. I am assuming the answer to this is to replace the drive but I just wanted to check with you experts before I start taking things to pieces. Is there anything else I should try first?
Many thanks in advance,
Ray
WDC_WD140EMFZ-11A0WA0_9RKZ85NL-20221125-1225.txt
Link to comment
  Only 75 emoji are allowed.
  • Create New...
