obowan Posted November 30, 2022 Share Posted November 30, 2022 Hello amazing Unraid community, I am experiencing an odd issue with my VM tower when upgrading to 6.11.x. I am currently on a Ryzen 7 2700x system with an RTX 3070ti and GTX 760, running a Windows 10 and macOS Big Sur VM respectively. On 6.10.3, the system works great. I can work on macOS and run games on the Windows VM simultaneously, without issue. I have the PC set to autoboot the WIndows VM upon the array startup. When I upgrade to 6.11.x, after a few minutes, the system will enter an odd "sleep" mode. I say "sleep" because the power button led on my tower blinks and when I press it, the system eventually resumes where it was, including restarting an VM's I had open. I believe the issue stems from my Windows 10 VM as the system seems fairly stable when running just the Mac VM. I've tried to upgrade to 6.11.2, 6.11.3 and 6.11.5. The same issue occurs each time. Diagnostics attached. Any guidance is appreciated orthanc-diagnostics-20221130-0907.zip Quote Link to comment
Solution JorgeB Posted November 30, 2022 Solution Share Posted November 30, 2022 Try uninstalling the S3 sleep plugin. Quote Link to comment
obowan Posted November 30, 2022 Author Share Posted November 30, 2022 Well that was easy. I feel like a dumby. Thank you for the quick resolution! 1 Quote Link to comment
