Alexmen97 Posted October 6, 2023 Share Posted October 6, 2023 Guys I have a problem, my server while everything is working suddenly I can no longer connect to the webgui either with connect api or with tailscale or with ginx via domain. The other things work like vm and docker Help me please I'm losing my mind. 😨 proserver-diagnostics-20231006-1214.zip syslog (1) Quote Link to comment
Solution Squid Posted October 6, 2023 Solution Share Posted October 6, 2023 It looks like the system up and rebooted on you a couple times trying to to get back up and running.  FWIW, you're using two different part numbers of memory sticks. Should be OK as the timings match between the two, but the most stable system is where matching sticks are used.  Instead of using XMP/AMP profiles for the memory, try setting SPD speeds in the BIOS to run at the 2133 speed that the memory actually is instead of the overclocked speeds.  Run Memtest for at least a couple of passes from the boot menu Quote Link to comment
Alexmen97 Posted October 6, 2023 Author Share Posted October 6, 2023 thanks, I followed what you wrote and so far the server has been accessing for 4 hours without problems. Thank you very much Quote Link to comment
