inspectornorse Posted October 12, 2023 Share Posted October 12, 2023 Diagnostics attached. My NAS is currently about half way through upgrading/rebuilding all of the disks for a little added context. Also if someone can share what to look for to determine whether the issue is serious or not that would be swell. I'd like to be able to do the analysis on my own if possible in the future. Appreciate the support as usual deathstar-diagnostics-20231012-1100.zip Quote Link to comment
Solution JorgeB Posted October 12, 2023 Solution Share Posted October 12, 2023 Oct 12 06:36:51 DeathStar mcelog: failed to prefill DIMM database from DMI data Oct 12 06:36:51 DeathStar mcelog: Kernel does not support page offline interface These are harmless, you can ignore. Quote Link to comment
inspectornorse Posted October 12, 2023 Author Share Posted October 12, 2023 1 hour ago, JorgeB said: Oct 12 06:36:51 DeathStar mcelog: failed to prefill DIMM database from DMI data Oct 12 06:36:51 DeathStar mcelog: Kernel does not support page offline interface These are harmless, you can ignore. Thank you friend Can you share your strategy for determining this? I see the entries you mentioned in syslog.txt Quote Link to comment
JorgeB Posted October 12, 2023 Share Posted October 12, 2023 It's quite common, just some missing info in the DMI. Quote Link to comment
