October 13, 20232 yr I'm trying to run Roon Bridge on a Linux Mint VM and play music via a DAC that is connected to the server via USB. No problem with connecting to the DAC, which shows up as a USB Device in the VM Setup page, but the sound is very poor - a bit like bad reception on a radio. I don't know if I might be able to improve things by passing through the entire USB controller, but unfortunately the motherboard has only one USB controller, and the unRAID flash drive is obviously sitting on it. This is the IOMMU grouping: IOMMU group 3: [8086:7ae0] 00:14.0 USB controller: Intel Corporation Alder Lake-S PCH USB 3.2 Gen 2x2 XHCI Controller (rev 11) Bus 001 Device 001 Port 1-0 ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 001 Device 002 Port 1-4 ID 0665:5161 Cypress Semiconductor USB to Serial Bus 001 Device 003 Port 1-6 ID 174c:2074 ASMedia Technology Inc. ASM1074 High-Speed hub Bus 001 Device 004 Port 1-13 ID 26ce:01a2 ASRock LED Controller Bus 001 Device 005 Port 1-6.2 ID 0781:5591 SanDisk Corp. Ultra Flair Bus 001 Device 006 Port 1-7 ID 0644:8043 TEAC Corp. TEAC UD-501 Bus 002 Device 001 Port 2-0 ID 1d6b:0003 Linux Foundation 3.0 root hub [8086:7aa7] 00:14.2 RAM memory: Intel Corporation Alder Lake-S PCH Shared SRAM (rev 11) Is there anything that can be done? The DAC is the TEAC device. (I appreciate that this is not the best way to get music to the DAC, and I am using other alternatives, like Ropieee on a Raspberry Pi, but if I can get this VM approach to work, it would be a nice solution for my use case.)
