JoseFromHD Posted November 8, 2023 Share Posted November 8, 2023 Howdy! I am currently beating my head into a wall about a file transfer issue. I am able to download from my NAS to my Encoding Machine at full 10GB speeds. I process the file successfully on my encoding machine and push it back to my Unraid server and I get 1GB speeds at most, usually 50mbs to 120mbs a second. I have tried the following: Ensured both my Unraid and my encoding machine have 10GB enabled Ensured my Unifi Aggregate switch is set to 10GB FDX (not Auto Negotiate) Ensured that that both devices are on the same subnet (10.0.0.X) Ensured on both devices the other NICs are disabled (Unraid SV has 2 onboard NICs and Encoding machine has 1 onboard NIC) I am a little new to Unraid and I am struggling to find the issue here. I am more than happy to provide logs if needed (may need some direction on how to pull these) Thank you for your assistance! Quote Link to comment
JoseFromHD Posted November 8, 2023 Author Share Posted November 8, 2023 Including screenshots of my Unraid configuration and my Unifi Config Quote Link to comment
JorgeB Posted November 8, 2023 Share Posted November 8, 2023 Start by running a single stream iperf test in both directions. Quote Link to comment
JoseFromHD Posted November 8, 2023 Author Share Posted November 8, 2023 Unraid to Encoding Machine Encoding to Unraid Quote Link to comment
JoseFromHD Posted November 8, 2023 Author Share Posted November 8, 2023 Moving from Storage (NVME SSD on Encoding Machine) to Unraid Moving from Unraid to Encoding Machine Quote Link to comment
JorgeB Posted November 8, 2023 Share Posted November 8, 2023 Iperf results are not great but not the current issue, unfortunately you have SMR drives in the array so not good for testing, do you have a fast disk or SSD you could use on the server to retest? Quote Link to comment
JorgeB Posted November 8, 2023 Share Posted November 8, 2023 It would also be good to test with a different Windows PC to rule that one as the problem. Quote Link to comment
JoseFromHD Posted November 8, 2023 Author Share Posted November 8, 2023 its currently writing to the SSDs as a cache first then writing to the array Quote Link to comment
JoseFromHD Posted November 8, 2023 Author Share Posted November 8, 2023 I dont have any other Windows PC's on the 10GB network Quote Link to comment
JorgeB Posted November 8, 2023 Share Posted November 8, 2023 13 minutes ago, JoseFromHD said: its currently writing to the SSDs as a cache first then writing to the array I know, but it would be good to test writing to different storage, in case the pool is the problem, modern disks can write at 200MB/s+, but your array is not good for testing because of the SMR parity. Quote Link to comment
JoseFromHD Posted November 8, 2023 Author Share Posted November 8, 2023 Would you like to me make another Share with just the SSDs as the primary pool, and try to write to just those devices? Quote Link to comment
JorgeB Posted November 8, 2023 Share Posted November 8, 2023 That should have a similar result, but you can test with a new exclusive share to see if there's a significant difference. Quote Link to comment
JorgeB Posted November 8, 2023 Share Posted November 8, 2023 Check that exclusive shares are enabled and active for that share. Quote Link to comment
JoseFromHD Posted November 8, 2023 Author Share Posted November 8, 2023 Settings for the Share Writing to just the SSD is super slow Quote Link to comment
JorgeB Posted November 9, 2023 Share Posted November 9, 2023 Which Unraid release? Don't see the exclusive share setting. Quote Link to comment
JoseFromHD Posted November 10, 2023 Author Share Posted November 10, 2023 I am on 6.12.4 Quote Link to comment
JorgeB Posted November 10, 2023 Share Posted November 10, 2023 Did you enable exclusive shares? Quote Link to comment
JoseFromHD Posted November 10, 2023 Author Share Posted November 10, 2023 I dont have that option. Quote Link to comment
itimpi Posted November 10, 2023 Share Posted November 10, 2023 4 minutes ago, JoseFromHD said: I dont have that option. Have you enabled it under Settings->Global Share Settings? Quote Link to comment
JoseFromHD Posted November 10, 2023 Author Share Posted November 10, 2023 I have enabled it Still same issue Quote Link to comment
JorgeB Posted November 10, 2023 Share Posted November 10, 2023 Without testing with a different client or pool difficult to narrow down the issue. Quote Link to comment
JoseFromHD Posted November 10, 2023 Author Share Posted November 10, 2023 Any other ideas on what I can try? I dont have another device on the Network that is 10GB but iperf works, so it seems to be a config issue Quote Link to comment
JorgeB Posted November 10, 2023 Share Posted November 10, 2023 Could be the pool or the client PC, if you don't have another device and since the array cannot be used for testing due to the SMR parity, can you break up the pool and test both devices individually? Quote Link to comment
