May 23, 20242 yr Community Expert Look under ssl/tls - edge Certificates and turn off Always Use HTTPS if it's on.
May 23, 20242 yr Author I just went to my Cloudflare settings and Always Use HTTPS was already disabled
May 23, 20242 yr Author I just got it to work by changing my SSL/TLS Encryption Mode from "Flexible" to "Full". I am now able to go to https://emby.domain.url and access my emby server. Thank you so much for all your help.
May 23, 20242 yr Community Expert Awesome! Now that your have public facing services you should look into how to best secure them as bots will try to attack you. All day, every day. So enable GEO blocking to only allow your country, this can be done in swag or in cloudflare. I have it set up in swag, but it's probably easier to set it up in cloudflare. Also look into setting up fail2ban which comes with swag. That will ban bots and bad actors if they try to log into one of your services or run scripts on them.
May 23, 20242 yr Author Great advice! That will be my next project, thank you for being so helpful in getting this set up. I really do greatly appreciate it
