Squirrel77 Posted June 22 Share Posted June 22 Hi people I am new to the world of unraid but managed to get my first server up and running using the basic package and all seemed to be working well until.... I had a power cut and now after powering on the server again the Webgui doesn't work from other machines on the network. So I attached a HDMI cable up to see what was going on and it just isn't booting at all, the PC sees the USB Drive and gives me the option to boot from it but then nothing at all happens on the screen it just stays black. How do I get it to boot again? Any advice much appreciated. Quote Link to comment
JorgeB Posted June 22 Share Posted June 22 Assuming you don't even see the Unraid boot menu, try recreating the flash drive. Quote Link to comment
Squirrel77 Posted June 22 Author Share Posted June 22 Sorry to sound daft but how do I recreate the flash drive? Quote Link to comment
Solution JorgeB Posted June 22 Solution Share Posted June 22 Backup the current one, recreate using the USB tool, see if boots, and if yes, restore only the complete /config folder from the backup. Quote Link to comment
Squirrel77 Posted June 22 Author Share Posted June 22 Ok thanks, will putting the usb in another PC and dragging and dropping its contents to a folder be an adequate backup? Quote Link to comment
itimpi Posted June 22 Share Posted June 22 9 minutes ago, Squirrel77 said: Ok thanks, will putting the usb in another PC and dragging and dropping its contents to a folder be an adequate backup? Yes. As mentioned the important part is making sure you have a copy of the 'config' folder as that contains your licence file and all your specific settings. Quote Link to comment
Squirrel77 Posted June 22 Author Share Posted June 22 OK thanks, I think my USB stick maybe on its way out as when I inserted it into my Windows PC it said a 'problem has been detected with this drive scan now to repair' which I did but Windows detected no errors..... So I am trying to recreate the USB now. Quote Link to comment
Squirrel77 Posted June 22 Author Share Posted June 22 Thank you JorgeB and itimpi my server seems to be back online after your help. Much appreciated. 1 Quote Link to comment
