June 24, 20242 yr Hello, I'm new to UNraid so please excuse my lack of knowledge regards to networking. I have set up UNRAID 6.12.10 on my new NAS (UGREEN NASync DXP4800, Intel N100 with I226-V NIC). My current setup is as follows: - 1 SSD Cache to Array - NAS connected to Eero via 1 Gbps Ethernet Switch - Client connected to Eero via 1 Gbps Ethernet Cable The issue that I'm currently facing is that Read and Write speeds are seem to be capped around ~60 MB/s, regardless of the use of cache (I get the same speed even if I directly write to the array: Here are results for iperf3 single stream: One thing that confuses me is that running iperf shows the speed is ~500 Mbps, while my network setup is capable of 1 Gbps and running speedtest from my NAS shows it is capable of 1 Gbps connection (getting ~960 Mbps down). Here is the diagnostics file: dxp4800-diagnostics-20240623-2026.zip Edited June 24, 20242 yr by selee14 upload diagnostic
June 24, 20242 yr Normal - that is parity write speed limit. If you need temorary more write speed, you can check the setting Tunable (md_write_method): Please make sure you are aware of the disadvantages setting this to read/modify/write (all disks powered on all time etc). I use that setting if i need to transfer huge amounts to the unraid server, afterwards i set it back to auto.
June 24, 20242 yr Community Expert Solution According to iperf results the LAN is the problem, try a different cable, switch, NIC, etc.
June 24, 20242 yr This as well, correct. Additional to parity speed limitation the network is obviously faulty as well.
June 24, 20242 yr Community Expert Are you using WIFI for either the server or client or any powerline Ethernet adapters?
June 24, 20242 yr Author Well, turns out the problem was my Eero. Bypassing Eero (connecting the NAS and Client to the same ethernet switch) gives me read and write speeds of ~110 MB/s, which tells me that speeds are limited to the 1 Gbps bandwidth. I guess it’s time for upgrade my 5 year old Eero 5 setup. However I will contact Eero support and see if my Eero is set incorrectly… Edited June 24, 20242 yr by selee14
