Jump to content
Help identifying system stop
Just want to start by saying that the unraid server is running under proxmox with GPU and Raid card passed through to the vm.
I went to check up on my server today after changing a GPU allocation, when I looked at the console output I was greeted with a strange log on the screen
I hope there are some people out there that are able to look at the screen log and to identify what could make this happen.
The info fo the VM is listed below
#Unraid file server
agent: 1,fstrim_cloned_disks=1
balloon: 0
bios: ovmf
boot: order=usb0;net0
cores: 8
cpu: host (AMD Threadripper 1950X)
efidisk0: sata-speed:101/vm-101-disk-0.qcow2,efitype=4m,pre-enrolled-keys=1,size=528K
hostpci0: 0000:44:00,pcie=1,romfile=1080ti.bin (GPU)
hostpci1: 0000:09:00,pcie=1 (raid card)
hotplug: 0
machine: pc-q35-6.2
memory: 24576
meta: creation-qemu=6.2.0,ctime=1670216047
net0: e1000= *redacted*,bridge=vmbr0,firewall=1
numa: 0
onboot: 1
ostype: other
scsihw: virtio-scsi-pci
smbios1: uuid=*redacted*
sockets: 1
startup: order=2,up=120
tablet: 1
tags: server
usb0: host=18a5:0302 (unraid USB key)
usb1: host=1c6b:a222 (USB dvd player)
usb2: host=1-9.4
vga: qxl
vmgenid: *redacted*
Thanks in advanced for the help
Link to comment
Since it may be related to visualizing Unraid I'm going to move this to the appropriate subforum to see if anyone can help, but if possible, would recommend trying to run Unraid bare metal, to confirm if it is related or not.
Link to comment
  Only 75 emoji are allowed.
  • Create New...
