Two Problems - License Not Found and 'corrupted USB stick'
I've made the plunge and tried to embrace Unraid.
Things aren't going really well.
- Started Trial on USBDisk1
- Trial Expired
- Trial Extended
- Formatted, Reinstalled to the SAME USBDisk1 (I'm quite sure on that part).
    During this process, I removed a 1tb Cache because it's a Cheap Temu Card, and it only has 1 port. A 1tb disk isn't big enough for me to utilize with Unraid (effectively, I get punished for having many small disks.  I just don't think that a cache disk should count as a 'storage device'. )
    I did a complete destruction of my Data
- At this point, I was still in my trial extension
- License Purchased, I thought that would apply it, but it didn't
- When I realized the license wasn't working, I tried to apply the Activation Code (not a file, just the code)
- COPIED (not moved) my data from WS2 and WS3 to Unraid3. I still have the data
- Trial Expired
- I tried to apply the license 2-3 times additionallly
I don't know how things are supposed to work
I just need to demonstrate that Unraid is STABLE enough to DELETE the data I copied from 4-6 directories on WS2+WS3.
At this point, I've had 2 RELATIVELY major problems with unraid, and I don't trust it enough to move forward.
How can I REALLY determine 'if my license has ACTUALLY been applied'
If my license HAS been applied, then can't I call Unraid for Tech Support?
Go to Tools - Registration to see current license status, and any issues regarding licensing you must contact support.
You can also post the diagnostics for us to see if there's a flash drive issue.
Do you have another copy of anything important and irreplaceable? Parity is not a substitute for backup, whether Unraid or some other system.
Yes. I have another copy.
But this is paid software, I need to be able to rely on it. I'll go hit the 'Contact Support' button I guess.
I don't understand your words, sorry.
My first attempt, I couldn't figure out how to use single-parity.   I can't afford to spend HALF of my storage budget on Parity. It took me forever to figure out how to do this properly.
I hit TOOLS > DIAGNOSTICS and it's giving me a 404 error.
I just tried it twice via TOOLS > DIAGNOSTICS
I even dialed in via putty and tried to do it at the CLI. nothing but errors
